Installed the Tailgate Table today
shimmy825
James
Los Angeles
2017 Mazda CX-5
As the title says, I installed the rear tailgate table today. Once i had the proper drill bit, it was pretty easy and looks great!
Ford Bronco Installed the Tailgate Table today IMG_2534
Ford Bronco Installed the Tailgate Table today IMG_2533
akturbo
Seattle Eastside
Nice! Did you use a stepped bit? Haven't had a chance to install my table, I've had it longer than my Bronco.
Ksjrb03
Tx
F250
Did yours not come with the drill bit and bit stop? Mine ordered 6 months ago came with them. Highly recommend using the bit stop so you don’t poke the outer skin.
shimmy825
James
Los Angeles
2017 Mazda CX-5
Mine did come with both, and I did use the bit stop. The drill bit was too big to fit into my power drill, so to home depot I went.
akturbo
Seattle Eastside
Lol, well, I haven't opened the box yet. I didn't expect it to come with usable tools!
BroncoMax21
Awaiting Wildtrak
What's your opinion of the quality of supplied jack nuts? Break any during install?
A few months back I read someone recommended buying some to use instead.
shimmy825
James
Los Angeles
2017 Mazda CX-5
they're shit. One broke during install but it was already in there and i was still able to secure the bolt to it so doesn't seem to be an issue but yeah, had I known that I would have gotten my own hardware.
Double IPA
Skip
Long Island, NY
2004 Nissan Titan, 2002 RS Warrrior
Any other tips or things you would have done differently (aside from drill bit stop and jack nuts)? Havent installed mine yet.
shimmy825
James
Los Angeles
2017 Mazda CX-5
it was easier than I thought it would be. The drilling is a bit scary but it worked out no problem
Tdub0527
Ted
Minneapolis
'21 Bronco Badlands, 2024 Rivian R1S
I bought this table before I read a bunch of threads with people having trouble with the Jack Nuts. I’m debating on returning mine. If I do keep and install I’d like to have my own hardware in the event something fails. What size jack nuts should I go buy and is there any other hardware you’d recommend getting?
shimmy825
James
Los Angeles
2017 Mazda CX-5
It's not that the jack nuts are the wrong size, they are just of poor quality. I'd take them and get four matching ones from a hardware store that are a little more robust.
Also, just make sure you use the limiter when drilling into the tailgate as not to over do it and damage the outside.
I've used this tailgate a few times and absolutely love it. Don't let poor hardware deter you.
Tdub0527
Ted
Minneapolis
That is the type of encouragement I needed. While I’d consider myself somewhat handy I have to admit I needed to Google Jack Nut because I do t think I’ve ever used one. I’ll head to the hardware store and pick some up and give this install a try soon.
Thanks!
patch1103
P.
Chicagoland
2017 JKU 75th Anniv. Edition
Definitely get replacement jack nuts! DO NOT try to use the included ones -- they are awful and you're almost guaranteed to break at least one of them.
This tailgate table, surprisingly, ended up being the most frustrating thing I've installed on any vehicle, and as a Jeep owner as well, I've installed a bunch. If I had to do it all over again, I would've looked at one of the aftermarket alternatives.
Mine is installed, but the right support bracket is slightly bowed, probably because my frame wasn't exactly square. I thought I'd compensated for that, but I guess I got one of the holes slightly out of alignment. One of these days I may remove, cut the jack nut out and try to realign with the help of some JB Weld, but I need to work up my motivation for that.
As it stands, mine works and is functional, but it also rattles something fierce whenever I hit the teeniest bumps in the road. Something else to see if I can fix.
Pattytester
Patty
Taco
Any idea what size the jack nut is? I don’t see it on any of the paperwork. I broke one too.
And, exactly what I’d expect of for to have shot quality and not provide an extra. Only surprise is I didn’t have to wait two years to get the table.
patch1103
P.
Chicagoland
