Image: Late Availability Tailgate Tray
bwomp91
Brad
2019 Ranger
Any word on why it isn’t available for the two door
There's a 12 cubic foot difference in space behind the 2nd row in 2dr vs 4dr. Just an issue of there not being enough real estate for it.
Brownie
Maple Ridge, BC Canada
Bronco Badlands, 1981 Trans Am, 1972 Austin Mini
Haha well that's why I ask....awful large panel for the jack and wrench. But oh man the Bronco comes with donuts!? Yum ;)
Ford Bronco Image: Late Availability Tailgate Tray 1605296893011
elmystico
Jon
New Mexico
2014 FJ Cruiser, 1990 Toyota pickup, 2021 Audi Q8
The cargo area apparently isn’t deep enough to make the depth of the shelf worthwhile.
They are also stating you can stand on the shelf, so there may be a limitation with the shallow depth to how much weight it can support.
Pray for aftermarket solutions.
elmystico
Jon
New Mexico
Headsong
Your welcome, it took years of experience and knowledge to learn how to use Google search for images. Since the BN interns have not gained that experience yet I present you with the two images to fill in the blanks. (/s) ?
Hmmm. So while one dimension in the camping thread shows width of 4'6", only 3'6" or so between wheel wells, which appear to be basically blocked off here. So only the width of the slider is all we get? I was hoping I could put a box in front of the wheel wells...guess not.
elmystico
Jon
New Mexico
JaxGtc
dangerzone79
O- -O
Bat Country
2022 Black Diamond & 1972 Bronco
Assuming this is the normal strap to pull up to get to your tire changing tools & jack. Right? If so... what happens when we get the tailgate tray? Seems like this would no longer be accessible. I assume it's a hard mount & won't be liftable.
Ford Bronco Image: Late Availability Tailgate Tray Tailgate Cover
North7
North Texas
SUV
Just remove the 4 tailgate d-rings to access the jack or carry it above.
RACERED-WT
2 Series
When I read late availability I think the manufacture has some valid issue like supply and demand. But, a fricken tailgate is now late availability!? Does this mean, that If I take delivery of my current Bronco that I cannot install the ford OEM tailgate later??
5280Bronco
Denver
Of course you can get it and install it later. But if you make it a part of the build itself, it may delay production of it. I'm just going to pick mine up later.
Used2jeep
Massachuvian
2007 Crown Vic P71
pan-y-cerveza
Manitoba
Tacoma Pro
For the amount of times I need those tools (I have never needed them yet. Knock on wood) I'm ok with having something over it that takes me a couple minutes to pull out. It's not like the tail-tray is welded in.
