IAG mud flaps
Bronco luv
Everglades
Louisiana
2024 bronco
Everglades
I have the new 2024 Everglades with the Sasquatch package and I’ve ordered the IAG mudflaps. They came with no instructions but I was wondering before I tried installing has anybody use these with the big tires? If so, was it a good fit, the company says it works with Sasquatch package I just want to make sure.!! thanks.
Lowcountry Bronco
William
South Carolina Lowcountry
I have the IAG flaps on my HE so yes, they fit. Try their video for install:
Someone should chime in to let you know about getting longer tabs but I used what came with it.
Billy Baroo
CA
Harley Davidson
I installed them several weeks ago, super easy to install and they work great with the Sasquatch package along with the factory running boards.
JL8jeff
Ewing, NJ
I put them on my base Sas and they fit fine with the hoop steps. When I added the Pro Comp wheels, they rubbed the flaps due to the -6 offset so I had to grind down some of the inside edge for clearance.
Ford Bronco IAG mud flaps My_Bronco4
JawnyBronco
DelMarPa
2023 Bronco 4dr
Here’s how good they look with the squared fenders…it is recommended to trim the fender by the mount hole or get longer clips at your hardware store to make threading the bolts easier
Ford Bronco IAG mud flaps IMG_7287
Ford Bronco IAG mud flaps IMG_7290
HolidayDog
Everglades
MT
24 Everglades
Everglades
I put these on my Everglades and they fit fine. Watching a video for instructions was kind of annoying but the video was well made, clear and concise. No yabbering.
I had to file out one of the holes for the clips to fit. Used a chainsaw file. It took some monkeying to get the bolts and nuts to connect but even
I put some black plastic thread nipples on the rear fasteners facing the tires. They were about an 1” too long. The black cleans them up to make them look less shiny.
So far they work great. I also added the IAG ez full length running boards.
Ford Bronco IAG mud flaps IMG_0284
CarbonSteel
Colorado Springs
2023 Carbonized Gray
I bought the front and rear i-line set and they fit and work well.
If I had to complain about something, it would be the fasteners. The are about 1" too long and stick out far too much in the inner wheel wells. So much so, I was concerned they would stick into the tires if the axle articulated enough.
I bought new ones that stick out just enough to put a jam nut on them.
Bill K
Allen, TX
Ford Bronco Big Bend 2 Door
Had the same issue with filing one of the holes with mine as well... Overall like the flaps though.
MattBrinks
Lincoln, NE
2024 Outer Banks Sasquatch
Anyone else having an issue with the flaps not quite sitting flush on the stock side step? The drivers side looked pretty good but the passenger side on mine is crooked.
Ford Bronco IAG mud flaps IMG_5277
Mundergun
Jordan
Nixa, MO
2023 4dr Velocity Blue 2.3MT Badlands
I just put the I line ones up front and I’m running Goodyear Territory MT 315/70R17 on a 17x9 +1. They fit well and look decent. Don’t like mud flaps personally but I’m tired of all the rocks on my doors lol. On a full turn I get a slight rub on the drivers side only. I don’t get why it touches on only one side but I plan to dremel the inner lip it touches and that should fix it.
AzGrayHeritage
Keevan
Georgia
Azure Gray Heritage 24
Can you post pics?
Mundergun
Jordan
Nixa, MO
sure here’s a picture from each side. On a full hard turn there was just a hair of rubbing on the inside so I took a dremel to the inner lips and it clears great now.
Ford Bronco IAG mud flaps IMG_2846
Ford Bronco IAG mud flaps IMG_2848
Ford Bronco IAG mud flaps IMG_2849
AzGrayHeritage
Keevan
Georgia
Thank you. I wonder if these would work with Heritage Running boards?
BigFootie
Wisconsin
