IAG Hood Struts Installed
JRock17
Justin
Jersey
Ice Mountain 4dr Wildtrak
Installed the IAG hood struts tonight. The install was super straightforward and easy, and took about 20 minutes. They work awesome, and lift the hood about 7 1/2 inches higher than the stock prop rod. This makes working underneath the hood so much easier. I highly recommend this relatively inexpensive modification!
Ford Bronco IAG Hood Struts Installed 8B1A48E0-E079-4BCE-9088-D01546A0473D
Ford Bronco IAG Hood Struts Installed FD094249-3134-4EED-96C6-650226AFEE78
Ford Bronco IAG Hood Struts Installed 85B5EB8A-7993-4C6C-88CA-1473949F9ADB
Ford Bronco IAG Hood Struts Installed 80B8F637-85C1-4B89-99CD-5709E7502600
mdk77
BM
Illinois
Bronco Base SAS
Nice. I have the same ones. One thing to note for folks, the hood will pop open rather quickly with these on once you release the latch. If you have a low overhead garage ceiling keep that in mind. The hood goes higher with these struts on then when using the factory hood prop.
