IAG Gloss Black Grille installed
Slick85
Richard
Austin, TX
Swapped out my Badlands grille with an IAG gloss black grille. Bought an OEM camera housing and Bronco letters to finish it off.
Fitment of the grille is 8/10. It required some flexing to get all the clips to line up. Top corners above the yellow side markers had a small gap that I do not remember being there before (See photo) maybe I’m wrong.
I thought letters were included with the IAG grille?
Bigred86
Curt
Thurmont, Maryland
2022 Ford Bronco, 2016 Harley Davidson Sportster48
Letters are included with the IAG grille they are just a little different shaped then OEM . Kinda "blocky". I am assuming OP didn't like this look and swapped to his factory letters.
O-BRONCO-O
O-BRONCO-O
Jordan
Southern CA
Yeah the letters that came with it are very blocky and don't look as good as the OEM ones
Slick85
Richard
Austin, TX
Oh ok, did you just use the ones from your stock grille or did you have to buy other factory ones?
O-BRONCO-O
O-BRONCO-O
Jordan
Southern CA
I just bought new ones from ford. I would have drilled out the old ones but wanted to keep the original grill all together. To install the new ones, I just used a soldering iron and melted down the back plastic tabs.
