IAG EZ-Lift Soft Top Assist
KhoiPhish
Altima
I guess I will email them. My thought was to wrap the strut body with sound dampening material. It worked in the past for a few other things on different vehicles.
Shouldn't have to do a janky solution. They sent me strut replacements, I'll try to get to it this weekend.
JFelty
Minnesota
Mustang Mach E
Let me know how the new ones do after installation.
JFelty
Minnesota
Mustang Mach E
@KhoiPhish I reached out to IAG again regarding my tube rattle and they sent me a set of new tubes. I installed them over the long weekend and no more rattles from the tubes :) I also fixed the rattle coming from the vent on the tailgate. On to finding the next source of noise :)
@IAG Performance thank you for the great customer service!
KhoiPhish
Altima
I still haven’t done mine, but I will today! Glad it fixed and glad they were good to you as well.
KhoiPhish
Altima
H
How’d you fix the tailgate rattle?
Sidenote replaced it, fixed the rattle. It was SO easy to replace, I have no clue why I kept putting it off lol.
JFelty
Minnesota
Mustang Mach E
H
I used foam gasket material with adhesive on one side of it. Cut out a rectangle stuck it to the backside of plastic vent and put it back. No more rattle :)
KhoiPhish
Altima
Any chance you can attach a picture of where?
JFelty
Minnesota
Mustang Mach E
I used this from Scamazon: Yotache Thin Weather Stripping 2 Strips Total 65 Feet Long 1/16 Inch Thick x (.25) 1/4 Inch Wide, 1.5mm Foam Gasket Seal Tape for Window, Sliding Door Jamb, Speaker, Dashboard, 2 X 33 Ft Each https://a.co/d/8YubNGZ
I popped the vent out starting on the side closet to the outer edge. Be careful there are some clips on the other side that could break off. I placed the gasket material close to the edge and stuck it back on the tailgate.
KhoiPhish
Altima
The long thin vent or the big chunky one on the hump?
JFelty
Minnesota
Mustang Mach E
Big chunky one. I forgot the other one was there it's hidden by my sub box.
Ford Bronco IAG EZ-Lift Soft Top Assist 1674102654150
MudMonsterRacin
PA
2003 Mach 1, 2016 F150
Installed the top assist on the wife's bronco today. Fast shipping and great product. Only issue I'm having is that the top is hard to close after I open the rear and get the struts raise it. I saw someone said you can adjust the latches by the tailgate? Maybe I missed what I need to adjust but if someone could help I'd appreciate it. The wife's not gonna like how hard I have to slam the rear to close it. Thanks in advance.
IAG Performance
IAG Performance
JJ
Westminster, MD
www.iagperformance.com
There are two nuts on each of the latches on each side. Simply loosen them slightly. You likely need to slide them in toward the middle just a little bit. We aren't talking much here. Start with 1/16" increments. It should take some force, but no more than closing any strut-assisted trunk or hood you are used to closing.
MudMonsterRacin
PA
I figured that was what I needed to edjust but I didn't wanna make it worse. Thanks!!!!
Smitty1979
Glens Falls
1968 F-100, 2016 F150, 2021 Bronco sport
I messaged you as well, I'm having the same rattle coming from the shock tube as the guy above did.
jorgem31
Jorge
Tampa
Mine has become worse. I messaged but never heard back and forget about it until I go for a ride. I may just pull them out at this point.
