HVAC Fan wind noise?
Sherminiator
CNJ
2022 Ford Bronco Big Bend, 2024 Bronco Sport Big Bend
Anyone else have an issue when their HVAC fan is running on a high speed (fan speed of 7 I think), that it sounds like wind noise that you get when driving at 70-75 with a hard top with the roof racks?
I thought I was just wind noise, but when I came to stop and still had it, I played with the fan speed and it went away.
Ibuprofen3293
Tom
Detroit
22MY Badlands
Yes 100%. Any fan speed at lower vehicle speed is fine because it sounds so consistent. Once I’m at highway speeds, any fan speed over 2 or so sounds turbulent, like the wind is forcing it’s way in. Dealer looked at it and said nothing was wrong (never mind the lack of airflow from the floor vents).
MistaGavin
Alaska
'00 F-150 & '68 Mustang GT
When stationary, if you crack a window, does the noise go away? Mine whistles a little on high but goes away when I crack a window.
Sherminiator
Sherminiator
CNJ
I'll have to to try that.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hey there! I can look into your Bronco’s noise concerns on my end if you’d like. Will you send us a private message with your VIN and dealership info?
MOBRONCO
MO
I have the same, seems actually related to the hardtop and pressure.
For me, in only happens when taking in outside air, as soon as I hit recirculate the noise goes away. If I open or crack either window, the noise goes away. What I found this weekend was the passenger side front top panel seems to be the culprit, if I release the rear outside latch the noise gets louder. If I pull downward on the latch the noise goes away. This mostly only seems to happen in below 40 weather, I think it’s a seal issue in the hard top that is somehow being impacted by the cabin pressure.
CarGuy
New Jersey
2023 Ford Bronco
My 2-week old 2023 Wildtrak has the same issue. I put the AC on and the fan is very loud and sounds like a wind rush and whistling, with little air coming from the vents. Nothing I do corrects it - i.e., trying to have it come out of certain vents, etc. Clearly something how the vents are blended depending on temperature. I'm gobsmacked Ford has not addressed this yet (@Ford Motor Company).
Ford Motor Company
Dearborn
Hi John. Can you send us a DM with your VIN and dealership info? I can look into this for you.
HopeHawk76
Cypress, TX
Honda CRV
I definitely get a whistle sound at higher fan speeds. I have a hard top as well.
KAQ
Keith
Camp Hill, PA
2023 OBX Bronco
I get the same thing on a regular basis
Ultimate
Brad
Bloomington, IN
2021 Ford Bronco Outer Banks
I'm experiencing the same issue.
TavisB
Pa
22 ManSquatch, 10 F150
I was able to eliminate this by adding some additional weather stripping to the hard top panels.
