How much aluminum?
limepickle
Sur
Dallas, TX
BMW Z3 Coupe (Clownshoe)
Does anybody know which body parts are aluminum? Is the frame all steel? So far I've only heard that the hood and swing gate are aluminum. I was hoping for as much aluminum as possible.
BroncoHooves
Austin, TX
Frame is fully boxed high strength steel. I believe doors are aluminum too.
Cobra Jet
2018 S550 / 94 Cobra SVT #13
Will the metal body panels hold up to corrosion and not be a repeat of the S550 hoods (mind you where such corrosion has been an issue on many Ford’s since 2005+)?
SliderJack
Jack
TN USA
FJ Cruiser, FJ40, SLK300, Viper
People don't necessarily realize aluminum has corrosion problems as well.
limepickle
Sur
Dallas, TX
True, but at least aluminum oxide does not flake away. In fact, the corrosion can actually be reversed without losing any metal.
SliderJack
Jack
TN USA
I just wanted to point out that it's not without its own problems.
It can make a mess under the paint. Or even result in holes.
Ford Bronco How much aluminum? wrangler door
MaverickMan
Shane
Still better than steel ive seen stuff out here with holes in 3 or 4 years.
Sgt Beavis
Rick
2019 Ford Raptor, 2018 Jeep Wrangler Sport S.
I wish they were using steel for the body panels. One thing I dislike about my JL Wrangler is that I can't stick on any magnetic armor to protect the Jeep from trail rash. I offroad my vehicles and I'd like to put something better than a wrap on to protect the paint.
Stampede.Offroad
SD
junk
Hopefully it is an extension of the philosophy behind the F150, in that the exterior panels are designed to be inexpensively amd easily removed and replaced.
aman43
pa
honda
I like the concept of aluminum body panels. if you take care of your car the panels will last forever. Not the paint. But the panels can always be repainted. only issue is if you get a dent you are in big trouble
limepickle
Sur
Dallas, TX
I've read that Ford invested in repair training and tools such that repairing aluminum parts is no longer expensive.
It seems like everything with body paint is aluminum. The only thing that Jalopnik didn't explicitly cover is the windshield frame.
OpenAir25
MA
Actually yes. This is a really cool feature of the Bronco that Ford hasn't talked about much yet for some reason. Both the front and rear fenders are designed to be user-replaceable. If you look at the photos in this thread, you can see that there exposed bolts on the top of the rear fender, in the door jamb, and under the hood along the top of the front fender. These handful of bolts are easily accessible and allow the fenders to be removed by the user. That means the fenders can be easily replaced if damaged on the trail, or they can be swapped out for aftermarket parts for a different look.
That is really cool :)
FirstOnRaceDay
Devin
Toledo Ohio
17 Civic, 19.5 Silverado
Meaning if you think the wrangler had some body kits booooy!
I’m betting right now your going to have a Bronco R body kit and “retromod square body” kit within months of launch!
