How do you wash your Bronco?
  • Wash by hand in the driveway or similar
    Votes: 227 76.4%
  • Automatic car wash or similar
    Votes: 70 23.6%
  • Total voters
    297
PSUTE
Western Maryland
Sierra
Once you go to stone road - you will then get new windshields every week
Yeah, well there are only 4 houses on the 1.5 mile road, so not thinking that'll be a problem. I am glad I got running boards, I hear the rocks bouncing off of them instead of my paint...
JaxGtc
I love this. I use a foam cannon on a garden hose because dragging out the pressure washer is a PITA for every wash.
I was in that boat as well. I had one water supply for the PW, one garden hose, and a PW hose, plus buckets and everything else.
Now one hose does it all. Super flexible with a swivel end and no headaches.
Skeld
Hampden, ME
2022 Chevrolet Silverado 2500 HD
Can the soft top hold up to a touchless wash without leaking?
Heymucko
Ken
Mustang
"With tears of joy if it ever arrives " ...should be a third option on the survey
710-oil-614
Cal
Columbus, Ohio
2023 Maverick Tremor, 2010 Toyota Tacoma
Hand wash only because of the soft top. Will likely use the pay and spray in the winter to knock down the salt on the underbody.
pequigah
Adam
Jeep Wrangler/Ford F-150/Ford Explorer Sport
  • Hand wash.
  • 2 bucket method w/ grit guards
  • Foam cannon
  • Pressure washer w/ angle attachment for undercarriage
  • Compressed air & microfiber dry
@SuperFord What pressure washer do you use? I’m looking for recommendations on an electric PW to use with a foam gun.
Ground_zero298
Scs michigan
Castro super clean on the tires and wheel wells, 2 coats of foam, power wash off (rotary tip), master blaster blow dry, then cerama detail spray if any tiny water spots dried before I blew them off. I try to minimize how many rags touch the paint.
Buck₩ild
Buck
Canada
Wrangler Willys, Bronco BD, Cherokee
I have OEM Ford roof rails & crossbar on.
Anybody gone through touchless car wash with them?
Gtrekker
Gary
NJ
Tried the drive thru car wash once bcuz I have unlimited washes. Way too many areas get missed when you have light bars and a 37" spare tire in the back.
pequigah
Adam
After having my Bronco for awhile w/ full PPF and ceramic coating, I've settled on the following:
When dirty:
When dusty:
After-wash detailing:
Wheels, tires, interior, exterior, etc.:
I've also learned that cleaning the wheel wells and undercarriage is much easier under full articulation. :p
Ford Bronco How do you wash your Bronco? tempImagekGhlS
broncoGIRL21
Sara
Detroit, Michigan
Jeep Wrangler
When dirty:
When dusty:
Question about the CARPRO PERL. Does is keep the matte finish of the bumpers and fenders? I'm still looking for a product that doesn't give it a wet/shine look.
pequigah
Adam
@broncoGIRL21 I've never put it on the bumper since mine is steel, but when diluted for external plastics (1:3) it's not shiny or wet looking.
On the other hand, if you didn't dilute it at all or went with a 1:1 dilution like what is recommended for tires, it would probably shine a little more. All depends on what you're after.
broncoGIRL21
Sara
Detroit, Michigan
Jeep Wrangler
Perfect. Thank you! :)
donniesp
Donnie
Asheville, NC
2019 Subaru
Former/recovering detail nerd... I have a pretty unique routine, I run it through a TOUCHLESS washer then dry it with Adams or Ammo NYC or whatever good stuff is on sale :) I also use quality microfibers (TRC) that are CLEAN AND FREE OF GRIT! I will pressure wash/foam bath first if it is really dirty, I try to get bugs off asap, I use detail spray and a pressure washer. I wipe down inside the door jambs tailgate etc. Detailing became like golf, takes too much of my precious free time away! My exterior routine takes 20-30 min TOPS. I vacuum it whenever it gets dirty or hit it with the blower (preferred).
KnoxGnater
Nat
Knoxville, TN
1934 Ford Roadster Pickup, Bronco Badlands
A word of caution on the touchless car washes (at least my local one). I started using it regularly to mitigate road salt, and noticed its dulling the finish on my pillar ditch lights. The Baja Design website says high pH (Sodium Hydroxide) will dull the coatings. They typically bump the pH up to facilitate cleaning without contact. I'll be working on restoring the finish back once it warms up a bit here....
