Hood Ditch Mounting Brackets for Everglades (Specifically) Help.
eqlol
Everglades
JP
Los Angeles
2023 Bronco
Everglades
Hey everyone,
Anyone have an idea where to get specific the hood ditch mounting bracket for the Passenger side specifically? Bought some Baja Design A-Pillars, I was aware the mounting bracket hole is covered by the Everglades snorkel. I was planning to macgyver'ing it lol but wanted to see if anyone else here knows of a bracket specific for this purpose. Thanks in advance!
eqlol
eqlol
Everglades
JP
Los Angeles
2023 Bronco
Everglades
For reference :
Ford Bronco Hood Ditch Mounting Brackets for Everglades (Specifically) Help. IMG_3781
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
To my knowledge they don't make one... because the snorkel completely covers that area
eqlol
eqlol
Everglades
JP
Los Angeles
2023 Bronco
Everglades
So I went with the double pillar mount from Rigid, so I can mount both on one side. Just waiting on delivery of the lights.
Just an update if any other Everglades owner is wondering the same thing. That was my solution to this lol.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Ya know we stock the Rigid mounts and lights from Baja Designs, Diode Dynamics & Rigid Industries... just saying :)
You may have an issue mounting it with the snorkel in the way though, since that snorkel sits over where the mount would go
eqlol
eqlol
Everglades
JP
Los Angeles
2023 Bronco
Everglades
I will definitely will be adding more lights soon! ;). Yeah, it was in the way so I went with https://www.rigidindustries.com/2021-ford-bronco-dual-pod-a-pillar-mount-kit-46721.html to mount just on the driver side since the snorkel covered the mounting area.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
samm88
Everglades
Sam
IL
Everglades
Had the same issue, ended up buying a dual light mount and installed both on the driver side.
Ford Bronco Hood Ditch Mounting Brackets for Everglades (Specifically) Help. bg6
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
Ford Bronco Hood Ditch Mounting Brackets for Everglades (Specifically) Help. 1710337755709-wo
