Heritage Package only available on the Big Bend?
joez
parts unknown
bronco
Is the heritage option only available on the Big Bend? Or is the lowest version of the bronco you can order it on? Also can you order any option that is available on the Big Bend (besides the 10 speed auto)?
Thanks,
Lowcountry Bronco
William
South Carolina Lowcountry
The "unlimited" HE is based on the Big Bend, no other models. So on that I take it that yes, all Big Bend options including the automatic and 2.7 should be available as long as it doesn't conflict with the HE package.
The Limited is based on the Badlands and is auto and 2.7 only, also limited to 1966 copies of each body style. These are the only two models the HE will be based on.
If you haven't read over the intro posting it's all covered ... https://www.bronco6g.com/forum/thre...d-unlimited-big-bend-heritage-editions.51234/
shoelessjoe
2013 Chevy Cruze
The "unlimited" HE is based on the Big Bend, no other models. So on that I take it that yes, all Big Bend options including the automatic and 2.8 should be available as long as it doesn't conflict with the HE package.
The Limited is based on the Badlands and is auto and 2.8 only, also limited to 1966 copies of each body style. These are the only two models the HE will be based on.
2.7
