Heritage Grill Item Part Number ?
holo37
Bucks Co PA
Jeep Grand Cherokee Limited
Now that the B&P is up for 2023 is the heritage grill going to be available from the parts department and if so does anyone have to item number?
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
broncorik
What is the bracket required for?
If you have BL or WT and you convert to Heritage you need that bracket...if you have base or BD your bracket is the same. The BL/WT grille opening are shaped like egg crates and the Base/Heritage/BD are shaped like rectangles and the bracket matches the edges of the openings. If you have BL or WT you also need the deflector (rubber edged like a squeegee that directs airflow to shutter gates).
Jtv107
Josh
Charlotte, NC
‘22 Bronco Wildtrak
We installed the Heritage grill this week. We found that the bracket is exactly the same as the bracket included on my Wildtrack that is equipped with a front facing camera.
Ford Bronco Heritage Grill Item Part Number ? bronco
Jtv107
Josh
Charlotte, NC
‘22 Bronco Wildtrak
Will post better photos in the sunlight whenever it stops raining. Also in the progress of installing IAG's interior lighting mod, which is one the hardtop is popped up.
Jr87mustang
Josh
Northern Cali
That looks awesome, do you have any other pictures of it?
Jr87mustang
Josh
Northern Cali
Jtv107
Josh
Charlotte, NC
‘22 Bronco Wildtrak
Amber turnsignal overlays are from @StickerFab (I've ordered a second set and am considering using two overlays to darken the amber a bit to match the sidemarkers better.)
Custom paint is by @Advanced Cerakote and looks amazing in person. I need to take better pictures when the sun comes out, could not be happier with his work and communication throughout the paint process.
@Jr87mustang Next up is white vinyl on the Bronco's doors, similar to yours. - Love that look and think it will tie in the grille's white colorway well.
Jtv107
Josh
Charlotte, NC
‘22 Bronco Wildtrak
Do you mind sharing what it cost to have the edge of the grill painted?
$1,350 for the OEM Ford grille painted in three colors, including the 'FORD' letters. Just FYI - The Heritage grill does not come painted white, its all black from Ford.
Jr87mustang
Josh
Northern Cali
I did the matte white, looks a lot cleaner to me than the gloss white does. It costs a little more (~$50) because its a color they don't stock but worth it.
Jr87mustang
Josh
Northern Cali
Didn't know it was all black, interesting. Is it smooth or textured like the other grilles?
