Heritage Edition: Best Front Mud Flaps?
jrollo7
James
NY
Range Rover Sport
Does anyone have a good solution for no-drill front mud flaps that work for the ‘24 Heritage Edition? IAG says they will have soon but their current flaps don’t quite work for the Heritage because it has a different/extra lip around the flare/running board area. Thanks for your help.
BigFootie
Wisconsin
My Mabett ones worked fine and I thought that the IAG’s were the same. I just had to order some longer speed nuts.
Lowcountry Bronco
William
South Carolina Lowcountry
I have IAGs, no issues with mine.
jsoa
Jose
Delaware
2024 Bronco 4dr
I also have the mabbet fronts and had same issue with the nuts, I also have some minor rubbing from time to time, usually backing out of the driveway
totaljustice
Kevin
Middle Sackvegas, NS
I just installed these yesterday. High quality and the install took about an hour. They do stick out from the stock Black Diamond fender flares about an inch but I like the extra width and they will probably sit flush with the edges on the wider models. Some of the supplied screws stick out a bit but it doesn't look like there is any way that the tires will strike them and you could always cut them shorter or use shorter screws.
LEPZ Mud Flaps Fits Ford Bronco Accessories 2021 2022 2023,Splash Guards Easy Installed for Bronco Exterior Accessory 2/4-Door,Fender No Drilling Required Front and Rear(4 Pcs No Logo) https://a.co/d/eBTzYoQ
Ford Bronco Heritage Edition: Best Front Mud Flaps? 20241007_115133
Ford Bronco Heritage Edition: Best Front Mud Flaps? 20241007_115122
Ford Bronco Heritage Edition: Best Front Mud Flaps? 20241007_115138
Ford Bronco Heritage Edition: Best Front Mud Flaps? 20241007_115149
jrollo7
jrollo7
James
NY
Range Rover Sport
Thanks. What size on those speed nuts?
I talked with an IAG rep yesterday and she said they were working on another version that works. I called because I was seeing conflicting ting info that they do work and other that said doesn’t eirk for Heritage models. Thanks for your reply -they obviously do work.
They look good. Hoping they work for the Heritage and the capable bumper.
Lowcountry Bronco
William
Here's the IAGs ...
Ford Bronco Heritage Edition: Best Front Mud Flaps? PXL_20231002_215202128
Ford Bronco Heritage Edition: Best Front Mud Flaps? PXL_20231020_173445261
I'll have to see what the new version is like but these fit fine.
BigFootie
Wisconsin
Here are the extended speed nuts I bought.
https://a.co/d/bTqWt4G
