Help in removing side trim…
Michael Grasso
Indianapolis
2025 Ford Bronco
Does anyone know how to actually remove this piece of trim?
thanks for keeping the comical comments to a minimum.
mg
BrentC
Brent
Calgary, AB
Are you referring to the B-pillar trim or one of the door trims? I see three “side trims” in this picture.
(asking for a friend…)
Michael Grasso
Michael Grasso
Indianapolis
2025 Ford Bronco
Fixed!
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
Open the front door and remove the rear door, slide the rubber weather stripping out from behind that moulding piece (one in each direction, front and rear). Then remove the bolts on the bottom of the moulding and remove.
GreyZ
Gulf South Louisiana
Turbo 350z, Bronco Badlands, Xterra
is there a diagram of this somewhere. I am not seeing the bolts. @flip
