Help - Forscan issue
Kmiller2098
Kyle
Massachusetts
2019 VW GTI
Need help, tried changing my tire size in Forscan followed all steps, now have a service 4x4 light that is unclearable. Reverted back to old settings and the light stayed on, anyone have any suggestions.
Bikeric
Tulsa
2022 Badlands LUX on 37's
2800mm is the maximum number you can input, so make sure you put in something less than that.
Desert_Brush
SoCal
2015 Mini Cooper
I had the same issue that I was able to fix through some forum digging. Give me some time to try and find it again.
Edit: Ok so after you change to tire size, make sure not to go over the max limit like what @Bikeric said. You are going to click on this box (in red).
Ford Bronco Help - Forscan issue 1677603410531
and then do the "AWD - Module Initialization/Relearn" but make sure to do it twice!
Then clear the AWD DTC code.
You will still have the PCM code now.
After that you want to go to the link provided by @D-TownBorn and go to page 8 and read the 2nd comment on that page. Skip to step 5 provided by @rtaylor. After clearing the DTC code for the PCM this should resolve the issue.
Or just follow all the steps provided by that. I did not change the tire pressure so you can probably skip that step. I have had zero issues since.
Pro Tip! Bookmark this information to share with other owners who need assistance.
