Hard Top Storage Cart?
Roofus
Swamp
M3/Bronco
I've been waiting for all of these companies that make storage carts for Jeeps to come up with a solution for us. The only thing out there - at least labeled - for our Broncos is this: https://www.extremeterrain.com/redrock-4x4-bronco-hard-top-storage-cart-j141594.html But some of our members have reported that upon delivery that this is just a remarketed Wrangler cart that does not fit.
Has anyone seen a cart built specifically for us? (I'm in a parking garage so this is my only option.) It's just shocking to me that after two years we still haven't seen a solution here.
cburke996
Santa Clara CA
'67 Firebird, E39 M5, Lotus Elise
Looking for the same thing...
Mike Kleen
Alabama
2022 EG Base MIC
Only things I've seen here are the DIY plans. That's what I'm gonna do.
mlcinema
US
Off Road
Is there still no solution for this?
CyberOrangeBadlands
Long Island, NY
‘22 Bronco
Looking for the same as well.
Some sort of cart on wheels or being able to hang it on a wall with hooks.
Have only seen the DYI type stuff.
DallasCajun
Will
Dallas, TX
2023 Ford Bronco Raptor
I repurposed my Jeep Cargo Cart for my Bronco. But since the Bronco top is a few inches shorter than the Jeep it doesn't tilt back to engage the support bar the way the Jeep top does. What I ended up doing was adjusting the legs inward as much as possible which now allows me to sit the Bronco top vertically (as opposed to at an angle for the Jeep).
This works better IMO as it takes up less space in the garage. I also installed some insulation pads on the bars for a better surface to lay it on.
Ford Bronco Hard Top Storage Cart? 1681219016585
Ford Bronco Hard Top Storage Cart? 1681219026525
There are tons of versions out there that appear to be the same basic product. Here's a sample and how the Jeep top sits on it:
Ford Bronco Hard Top Storage Cart? 1681219157521
Ford Bronco Hard Top Storage Cart? 1681219239128
Roofus
Roofus
Swamp
M3/Bronco
TopLiftPros just introduced the “Venture” model which folds up into 2 boxes for storage.
I still have never seen a purpose built cart for our tops. I worry about putting too much pressure on the back glass with the Jeep versions.
1979
Ben
Baltimore, MD
2023 Bronco Raptor
I just got the Venture. It does not fold up into 2 boxes for storage. You have to disassemble it in order to do that. The marketing is misleading. I’m planning to replace the bolts with quick release pins to make the process easier but it’s definitely not just a quick fold up and go thing.
Roofus
Roofus
Swamp
M3/Bronco
That’s good feedback! I was planning on finally breaking down and just paying the premium for one of these this summer since no one seems to be interested in building a purpose built cart. I’ll probably just get the normal one if that’s the case. I know they have a sort of 2.0 version of the original on the way as well.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Before I realized this was sitting on a dolly, I thought you had rested it on the ground like this. Internally I was screaming. :ROFLMAO:
Nice solution!
CyberOrangeBadlands
Long Island, NY
‘22 Bronco
Nice solution!
How are you protecting the back window? I know its only 80 lbs but it seems like the entire weight of this is resting on the back window.
ExtremeTerrain has a solution but It stored horizontally.
Still searching for a cart that can store a 2 Door Bronco HardTop vertically.
DallasCajun
Will
Dallas, TX
Decent concern to consider. The weight is actually split across the top/edges and the window as the cart sits on both. I also have some pipe insulation and towels underneath to cushion it pretty well.
CyberOrangeBadlands
Long Island, NY
‘22 Bronco
Thanks for the response.
So you just put this on a regular dolly and padded the bottom? Or did you modify the Extreme Terrain solution?
If you can please post a picture of the “dolly” without the Hardtop on it.
