Handle swap - blue to orange
WildtrakBronco
Pennsylvania
2022 Bronco
continuing with my orange accents, I knew I had to make this happen. The orange handles I bought came with the gray plastic and not the tan that mine has. Simple fix; 2 screws to swap out the colored handle piece from one to the other. (y)
Ford Bronco Handle swap - blue to orange IMG_3426
Ford Bronco Handle swap - blue to orange IMG_3427
Ford Bronco Handle swap - blue to orange IMG_3428
Toccoa
Isuzu Rodeo Sport
Nice swap. (y) Although, we all know that color is yellow masquerading as orange. :LOL:
7722 Bronco
Kentucky
2020 Explorer ST/ 2019 F350 CC DRW 4x4
I need to order a set of the Heritage handles, seems they are red to match my red/black theme on my Race Red Wildtrak.
Ford Bronco Handle swap - blue to orange ford-bronco-heritage-limited-edition-2023-25-interior-front-row-scaled
7722 Bronco
Kentucky
share some before and after pics! would like to see your transformation too
I will.
I'm really considering installing the red handles and leaving them as they are on the black frame instead of swapping them over to the tan. Since I've gone with the black and red seat covers and that's the theme that has evolved for the Bronco, I'm thinking they will look good just as they are. More utilitarian looking leaving them black. With all the black around the handles from the lower dash and A pillar and instrument cluster, it should look fine.
Ford Bronco Handle swap - blue to orange 20231023_140742
Ford Bronco Handle swap - blue to orange 20231024_120347
Mikey1287
22 Bronco, 72 Mach, 03 Mach, 69 Mach, 08 Harley
I changed mine about a year ago just as you said and left the black/red. Recently took them apart and switched back to the tan/red by taking out the two screws.
I can say both ways look ways look good :)
I will.
Skott
Missouri
2022 Bronco
I have a WT, with the tan & blue handles. I'm interested in swapping for the red & black handles.
Are you saying that you're able to take the red & black handles apart, and put the red striped piece from the red & black handles into the tan piece?
If so, do you have photos of the swap you've done?
I don't think I want to replace my handles without seeing how the red & black handles look in a WT, or without knowing if I can swap the red stripe for the blue stripe in the original handle.
Thanks.
Mikey1287
Yes you can take them apart with a torques bit. Just 2 screws on the inside.
I don't have any photos of when I had the black and red on, but here's the tan/red.
The red and black actually looked better than I expected. I may end up switching back to that.
Hope this helps.
Ford Bronco Handle swap - blue to orange 1024231210_HDR
Ford Bronco Handle swap - blue to orange 1024231210a_HDR
Thanks.
WildtrakBronco
WildtrakBronco
Pennsylvania
2022 Bronco
Hope this helps.
chef's kiss!
Sprinkles on the icing of your cake might hopping on Etsy and getting red replacement tabs for your vents to further eliminate the blue. I have orange on the way for mine :cool:
7722 Bronco
Kentucky
Thanks.
I'll post the black/red here in a few. The blue does just pop right out.
Ford Bronco Handle swap - blue to orange 20231024_123936
Bubbbba
Ohio
None
Hope this helps.
On badlands switched out black to gray on handles Esty vent tabs
Ford Bronco Handle swap - blue to orange IMG_0407
Mikey1287
Looks good.
I've been thinking about doing the tabs. How easy are the to install?
Do you remove the old tabs or are those just overlays?
WildtrakBronco
WildtrakBronco
Pennsylvania
2022 Bronco
haven't received mine yet, but I watched the install video and they are replacements. Flat blade screwdriver to press up on the bottom of the vent, pull it out and then swap the colored tabs.
