Grimm ARB mount questions
jawest12
Aaron
Northern Virginia
Toyota Tacoma
For the Grimm arb compressor mount two questions for the collective, or Grimm if they are watching :) :
1. Any warranty concerns with how it mounts the ecu?
2. Any concerns with the vibration transferred to the ecu?
c00kedg00se
Andrew
Boise, ID
LR2, Expedition, Bronco
Following....
Dover157
Ben
Moriarty NM
2022 Bronco Black Diamond
Dealership didn’t say anything about mine last two times they had it. Have used it probably a dozen times so far and no issues with the ecu. If you have a short temper and don’t like playing “where did that bolt go” may want someone else to do the final install though. Getting those three factory ECM bolts back in is a pain.
jawest12
jawest12
Aaron
Northern Virginia
Toyota Tacoma
Agreed. The install was a bit tricky. But I like the setup.
UtahBrandon
Brandon
www.puravidaoffroad.com
a number of classics and my 4dr Badlands
I added rubber grommets between the ecu and the bracket on mine, hoping to minimize any potential future issues.
