Greetings from Baja Designs!
Baja Designs
Baja Designs
San Marcos
It would be great if you guys came up with one that sits for flush with the windshield. For those without a roof rack and not to add height to the Bronco.
Ok great. Thanks for the suggestion. You might run the risk of causing too much glare, as the light bar would have to sit pretty forward and low - whereas farther back some of that glare would be reduced.
We will certainly take a look though. Make sure to shoot me a private message if you happen to know of one we can measure :)
Machine Gun Fury
Carl
Southeastern USA
2021 Ford Bronco Outerbanks
How do your rock lights compare to the Rigid lights from factory? Are your LP4's around the same size as the factory Rigid pod lights?
Frank N
Frank
NJ and Outerbanks
2018 Ford Raptor
Ford is already in bed with Rigid for factory and or dealer installed lighting.
Ford got in bed with the wrong off road light company, Baja Designs all the way.
Baja Designs
Baja Designs
San Marcos
Hello!
I am not actually sure which factory lights will be released on the Bronco, but I can say with almost 100% certainty that there isn't an OE/factory light available today that will come close the the performance of the LP4. Even in comparing to other offroad auxiliary lights, the LP series is at the top of the pack in regard to output and pattern.
As for rock lights -it has been a few years since I have seen one of their rock lights in action. Most rock lights I have seen from the top lighting manufacturers are all fairly similar in output.
Used2jeep
Massachuvian
2007 Crown Vic P71
*Wink wink* *nudge nudge*
Machine Gun Fury
Carl
Southeastern USA
Hello!
Awesome, one more question in regards to the LP4. If you have the aux switches in your bronco in your design how would you switch between driving and spot lighting?
Used2jeep
Massachuvian
2007 Crown Vic P71
Have AUX 1 linked to a relay that is tied to your low beams (this would turn on your fog lights) and then AUX 2 would power a relay hooked to your spot beams (that would be powered from your high beams).
Baja Designs
Baja Designs
San Marcos
Hey guys - Just wanted to share a brief announcement.
Temporary LED Change
Wednesday, February 17, 2021
Due to a global pandemic Baja Designs has experienced an increased scarcity of LEDs in our tightly controlled temperature range. This shortage affects our OnX6+, LP6, LP4, XL80, Squadron Pro, S2 Pro, and S1 series of lights. Rather than halting production at our San Marcos, CA facility, Baja Designs has opted to source LEDs in a lower color temperature range without sacrificing the performance and quality enthusiasts expect from Baja Designs. Beginning February 17th, 2021, Baja Designs will be shipping lights with a combination of LEDs ranging from 4000k-5000k.
Although we have long established that 5000k is the ideal color temperature, LEDs in the 4000-4500k color range are preferred to alternative LEDs more commonly available in the 5700K and up ranges. As such, we find that this solution is the most favorable option to continue manufacturing a premium product.
If you have any questions or concerns about this temporary LED change, you can ask here or DM me for more info.
Ford Bronco Greetings from Baja Designs! 4000k vs 5000k
BadlandsBronc21
Christopher
2013 Toyota Tundra Crewmax 2018 Audi S5
Welcome Paul and the discount is much appreciated!
Bronco4lyfe85
William
2019 Challenger Scat Pack
Make a light as bright as the sun and you got a deal.
Outbound Exploration
2018 Chevy Sonic Hatchback RS, Looking to upgrade to Bronco*
So I'm hoping to pick up my 2dr Badlands from Kearny Mesa, could I swing by delivery day to get something put on by your team? 😎
wvmtneer
‘Merica
F-150
I think they already do, and I am excited for their harness kit for the Bronco.
