Gravity Pro6 and Flex Era pods install.
TC1
Tony
Norwalk, Iowa
2022 Bronco, 2022 Mach E, 2024 Escape, 2022 F150 Powerboost
Installed a couple PRO6 spots on bumper and ERA 1 pods ditch lights. Decided on KC Hilites because I wanted that retro look. Spent about 4 hours with the mock up and wire routing.
used a Texas Complete mount on the bumper. bolt hole/bumper match was perfect. It’s easier if you pre mount the lights. Pods were mounted on sevensparta super easy install once your wiring is installed. KC hilites were great plus online videos on how t trim the wiring for aux switches. Anyway here are my pictures.
Ford Bronco Gravity Pro6 and Flex Era pods install. A4F919D5-B5E6-4CB9-B237-9939C9D3140F
Ford Bronco Gravity Pro6 and Flex Era pods install. 2DBA9BA8-F721-4913-B819-E1066FEC18C6
Ford Bronco Gravity Pro6 and Flex Era pods install. 1C09D45D-8A29-45C6-85B8-827A6AD68681
Ford Bronco Gravity Pro6 and Flex Era pods install. B2DD93D8-61B7-4FF8-98A5-60FFC8D720DC
Ford Bronco Gravity Pro6 and Flex Era pods install. C2985660-4D7C-4452-AAEC-1C38483929E8
Jakethesnake
Jake
Philadelphia pa
2007 GX470. 2002 Suburban. 2016 Subaru Impreza
Looks great ! I also went with KC Hilites. Slimlites, flex era 3 duel modes and flex 1’s. Hope to fit them all on a VR performance front bumper mount.
1. how was the wiring?
2. any chance of getting some night pics with them on and how about a look at the amber backlight on the flex 1
  • Like
Reactions: TC1
TC1
TC1
Tony
Norwalk, Iowa
I will try and get a few shots tonight in the dark. The wiring was straightforward. They had videos on the Upfitter switches, which was awesome.
Deleted User 5719102
Who's
On a Lake
22 2dr
Ford Bronco Gravity Pro6 and Flex Era pods install. giphy (4)
TC1
TC1
Tony
Norwalk, Iowa
update on lights. One of files is too large to load up. So last are normal high beam and then bumper mounted spots.
Ford Bronco Gravity Pro6 and Flex Era pods install. 3C5E5446-8F51-425E-8A95-D92DC2F760BB
Ford Bronco Gravity Pro6 and Flex Era pods install. 7F44C99C-F836-49BF-9938-16FBA2A7E244
Ford Bronco Gravity Pro6 and Flex Era pods install. 63EC9582-AB2B-41DC-9317-5EF7601D8B21
Jakethesnake
Jake
Philadelphia pa
DAYMN ! Looks great TC1. Hopefully picking up my bronco today. This only makes me more excited to get my lights on it now. Thanks for doing the pics and video. Appreciate you
  • Like
Reactions: TC1
Johnny Mo
Westchester County, NY
teachu2shoot.com
Did you setup the backlight on the A-Pillar lights? off the DRLs? I've got Flex Era 4 combo beams and I'm debating on the DRL backlight (would mean no covers) unless I throw the DRL on a switch (which seems a waste)
Joe Canuck
Canada
2022 Ford Bronco Badlands Advanced
I just bought the FLEX ERA® 1 - 2-Light Master Kit and even after watching the Upfitter switch video I'm still confused which wires to cut. As the video showcases a harness without the relay. I've attached a photo of the harness diagram.
Any help on this would be fantastic, how did you install the Era 1's ditch lights on your bronco upfitter switches?
Ford Bronco Gravity Pro6 and Flex Era pods install. Screenshot 2023-05-19 at 4.06.40 PM
TC1
TC1
Tony
Norwalk, Iowa
You cut them down to the red/white and black wires. So the relay is not part of the circuit (doing this will change how it operates with the KC switch). Attach the ground to a existing body ground for easy point. then verify the white and red power cables with a quick test to see which is the back light and hook it up to A6 wire (i also hooked my grill clearance lights to it). I hook the lights up to A3 in my case as the big spots and driving lights are on A1 and A2 as they have more power. the wiring diagram is on the site here as well. There are a few you tube videos as well I watched and helped me too.
Joe Canuck
Canada
Thanks for the help, I figured it out now. I found a really good video as well, that helped. For anyone else having any issues checkout these videos for installing the Flex Era 4's which is very similiar.
Also reached out to KC and they suggested this video:
