Goat Mode Dial trim swappable?
Epiphany
Upstate
'24 Bronco
As part of the clown show reduction program on my '24 Bronco Raptor, I changed my Goat Mode ring to a silver one that is a reasonably close match to the Iconic paint color the vehicle has. It helps if you use a couple of picks to release the two tabs that hold the ring on. Just pulling the ring upwards felt a bit risky so I only went so far before deciding to finish using the tools I mentioned. New ring snaps right in.
Ford Bronco Goat Mode Dial trim swappable? 20240720_184117 copy
Ford Bronco Goat Mode Dial trim swappable? 20240720_183630 copy
Ford Bronco Goat Mode Dial trim swappable? 20240720_183814 copy
acrawshw90
Alex
Illinois
2024 bronco big bend
I’m looking for a replacement for my bronco that got all scratched up where were you able to buy just the trim ring
Epiphany
Upstate
'24 Bronco
As the text you quoted of mine above the photo implies, I used picks to remove the ring from an entire assembly I purchased from Ford. They don't sell just the ring on its own.
Ford Bronco Goat Mode Dial trim swappable? 20240418_134008-X5
