Getting ready... What other accessories / preparations?
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
I'm planning on getting a pack of these for my family of 4:
Emergency Blankets & Rain Poncho Hybrid
Basically a tougher version of the common mylar emergency blanket, but in a poncho form.
Daktari
Oliver
good things here! I'll definitely have to get a set of good recovery gear and I really like those Element fire extinguishers mentioned here.
I won't have a winch until there's a better solution, best inside a bumper. But I also won't be anywhere where I would need one for a while. I'm also thinking about just have one mounted on a plate to attach to the hitch and get a bumper with front hitch receiver, so I can have the winch on either side if needed and leave it at home when I'm not out on a trail.
Air down tool and some kind of compressor to fill them back up, but won't be spending top $ on that for a while, I don't live close enough to any trails where I'd be doing this every weekend. If needed it would be a later addition.
Some extra lights will go on too, I don't really like light bars on top, so looking for other options eventually. little pods by the mirrors and maybe a bar on the front bumper and some light towards the back.
I'll also be getting the InReach or similar as I'll definitely be out of cellrange and by myself.
The rig is crazy expensive already, so I have to budget and buy carefully for a while.
Oh, need to get a new tent too.
Keep the ideas coming!
Hoofnmouth
mark
N ca
ford focus st
Life flight insurance, satellite emergency locator beacons, sat phones? You guys planning a trip across Africa or Tibet expedition?
I do alot of stuff my insurance guy would cringe over lol,life flight insurance can be used anytime anywhere weather permitting.
My buddy hit a deer on his dual sport and used his. I think you can give it to a family member too if needed.
BEM-S4
Philadelphia
BMWs & Porsches
I just spoke with Paul at Element Fire Extinguishers. I am familiar with Halotron which is a different technology, but in simple terms after you use it everything turns to gas and there's no mess to clean up. The Element is also mess-free, the discharge will not leave a giant (and expensive to clean up) disaster. The 50 second and 100 second are exactly the same and output the same material per second, the 100 just lasts longer.
One item of note, many of the mounts only work for the 50 but they are developing stuff for the 100 that will be out this summer. I plan to keep my H3R in the BMWs but get the Element in the Bronco seems like a great - and cost effective - solution. Much smaller form factor too.
Ryuk
PA
2021 Ford Ranger, 2023 Ford F-150
I am confident they will have a mount for the 100 second ones before we take delivery of our Bronco's
MadMan4BamaNATL
Ray
Atlanta
Isn't it expensive?!!! With the winch I'm just over $60K for a 2dr BadSquatch with Lux. However, I don't want to feel forced into suspension upgrades almost immediately.
Your logic on the winch and other areas listed here makes sense. Compressors are difficult decisions unless you go wheel very often. I sort of do already and will even more often with the Bronco and you find other uses for it, but still $$.
I have a winch now on an older 4x4 and use it for other guys more than myself, but I do over prep for wheeling. Recovery gear has always been my top priority since I'm not a mechanic. This Bronco won't see anything serious though for several years. I won't baby her, but there won't be much in the way of rocks in her future until I do upgrade the suspension after her 4th birthday. :)
Natai
Sean
Sacramento
Here's my current, WIP list. As this will be my first off-road vehicle - and the first I'll be adding any aftermarket to - there's a lot of stuff I need to get. We'll be keeping both of our current vehicles as well, so even basic stuff won't be moving over from my Nissan.
I've been trying to do a lot of research on what I'll need to prioritize, and I'm also trying for a reasonable quality/value balance. Cause this is getting pricey. (What I'm getting from Ford is around $1500, the rest is another $4400) If anyone has any recommendations on what I should re-think, please tell. (The Element extinguisher seems like an awesome, no maintenance alternative that takes up less space.)
Basics (always on board)
Aftermarket Item DescriptionManufacturer /SourcePriceLink
Element E50 Fire SuppressionElement$78.14https://amz.run/4JiF
Emergency Blankets & Rain Poncho Hybrid, 4-packPrepared4x$19.99https://amz.run/4JiA
Jumper Cables, 20 ftEnergizer$22.99https://amz.run/4Ji8
LED Road Flares Disc Beacon SetTwinkle Star$23.49https://amz.run/4Ji9
Multitool$-Already have
Synthetic Leather Winch Gloves w Kevlar ReinforcementWARN$29.68https://amz.run/4JiX
Tire Repair KitSmittybult$24.13https://amz.run/4Jhm
Waterproof First Aid Kit and Small Kit BundleSurviveware$113.95https://amz.run/4Jhs
Emergency (anytime we leave the city)
5-Way Power Solar Hand Crank Radio, Powerbank, FlashlightMesqool$29.99https://amz.run/4JiB
Compass$-Already have
Garmin inReach Explorer+Garmin$442.49https://amz.run/4JiD
LED Origami Lantern$-Already have
NOCO Boost HD GB70NOCO$199.95https://amz.run/4Ji3
NOCO Protection CaseNOCO$24.95https://amz.run/4Ji4
Recovery A (Higher priority recovery gear)
Alltrade 640912 Black 3 Ton, All-In-One Bottle JackPowerbuilt$62.59https://amz.run/4JiE
Collapsible Shovel$-Already have
Combo 20' Recovery Strap and Shackle Hitch ReceiverRhino$69.97https://amz.run/4Jho
D Ring Shackles 2 packRhino$21.97https://amz.run/4Jhp
Kinetic Recovery Rope 7/8" x 20'DitchPig$88.06https://amz.run/4Jhu
Recovery Boards, X-BULL, Gen3, OrangeX-BULL$89.90https://amz.run/4Ji0
Soft Shackle, 2 pack, Orange, 7/16" x 20"Ucreative$30.99https://amz.run/4Ji2
Trailer Hitch LockRhino$19.97https://amz.run/4JiC
Tree Saver 3 inch x 8 footRhino$19.97https://amz.run/4Jhn
Recovery B (Lower priority recovery gear, later purchases)
Hi-Lift Handle KeeperHi-Lift$14.05https://amz.run/4Jhw
Hi-Lift JackHi-Lift$89.89https://amz.run/4Jhk
Hi-Lift ORB Off Road BaseHi-Lift$41.17https://amz.run/4Jhl
Universal Snatch BlockSmittybilt$29.30https://amz.run/4JiP
Wheeling
Coyote Automatic Tire Deflators, 4 to 56 PSI, 4 PackCoyote$89.39https://amz.run/4Jhy
Ford Performance by ARB Off Road/Track Air Compressor KitFord$369.00
INDEFLATE 2 Hose Tire Inflation and Deflation ToolIndeflate$174.99https://amz.run/4Jhz
Upgrades
(A couple of these are placeholders until a Bronco compatible item is available. Also still debating between Diode Dynamics and Rigid, but prices are comparable.)
13 inches Flexible Rubber Antenna ReplacementRydonair$24.99https://amz.run/4JiJ
Cargo Area Enclosure,Deluxe Raised Lid, 4DR by TuffyFord$579.00
Cycline LED 6-Ligth Rock Light KitKC HiLites$282.99https://www.kchilites.com/cyclone-led-6-light-universal-rock-light-kit.html
Horse Sounds Car HornBoom Blasters$39.99https://www.boomblasters.com/product/horse-sounds-car-horn/
Hothead Headliner incl window panels and sound assassinHothead Headliners$550.00Price estimated based on JL
OBDLink EX FORScan OBD AdapterOBDLink$49.95https://amz.run/4JiG
SS3 LED Fog Light Kit, Bracket OnlyDiode Dynamics$80.00https://amz.run/4JiN
SS3 Pro Amber SAE Fog PairDiode Dynamics$300.00https://amz.run/4JiK
SS3 Pro White SAE Driving PairDiode Dynamics$300.00https://amz.run/4JiL
SS3 Pro White SAE Fog PairDiode Dynamics$300.00https://amz.run/4JiM
Table for swing gate by TuffyFord$199.00
Tools
300 PCS Heat Shrink Butt ConnectorsQibaok$16.99https://amz.run/4JiH
BIG RED Torin Steel Jack Stands: 3 TonBIG RED$31.35https://amz.run/4Ji6
Blackhawk B6350 Jack - 3.5 Ton CapacityBlackhawk$135.38https://amz.run/4Ji5
Pro-Lift C-2036D Grey 36" Z-Creeper SeatPro-Lift$36.48https://amz.run/4Ji7
Wire Stripper Crimping Tool KitKOTTO$22.99https://amz.run/4JiI
Care
Aerospace 303 UV Protectant and Dust Repellant303$15.77https://amz.run/4JiS
PPF (Leading Edges and Grille)Maybe not, likely $2k+, just for bugs on highway at night
Fun Extras
GoPro Hero8GoPro$299.99https://amz.run/4Jhx
Top, Soft Canvas, Bimini, 4dr by BestopFord$339.00
Rick Astley
Up Doug's ass
d
You're going to need that load rating with so much crap in there on a constant basis!
FWIW, i've had very poor luck with NOCO products as have a few friends and some folks stuck in BRC. They are the darling of Amazon (which says a lot right there) but I was very grateful when the third warranty replacement at Batteries+Bulbs allowed me to switch to Panasonic brand trickle charger and jumpers. B+B here in the greater Seattle area won't even carry NOCO anymore due to excessively high warranty replacements (franchised ownership allows them to carry an array of brands if supported by their national office, as far as I understand their franchise agreements).
Natai
Sean
Sacramento
Very little of that will be on board on a regular basis. If I get into camping or overlanding down the road, then load rating is going to hit me hard.
I've done some searches and read some reviews, but there seems to be very little consistency in terms of which jump starters are supposed to be good. Usually I find some commonalities across recommended lists and the like, but not so much with what I've found so far. NOCO was at least consistently mentioned, but that could just be because it's popular.
mrjerry469
JERRY
BLACK DIAMOND
Wheeling
Upgrades
Tools
Care
Fun Extras
Making a list using your very extensive list and checking it twice lol
BEM-S4
Philadelphia
BMWs & Porsches
Not sure if it's an issue on this type of vehicle but did you have a dead blow hammer on your list? Most of my cars, especially in the winter, the wheels get stuck to the hubs and need a good knock to remove them. Beats climbing under the car for a swift kick.
My Cannonball kit also includes a couple of reflector vests, a reflective triangle and some road flares. My nightmare is a roadside wheel and tire change at night, danger of getting hit by oncoming traffic.
Rick Astley
Up Doug's ass
d
I'm not very big on this guy's videos overall, but at least he has a multimeter to test with....
Which Car Jump Starter Is Best? Let's find out!
I have had one of these for a few years and it's had about 15 flawless starts up to and including decommissioned military vehicles turned into mobile party platforms in 120+ degree temps and stored in an trailer all year between uses.
https://antigravitybatteries.com/products/micro-starts/xp-10-hd/
Natai
Sean
Sacramento
Yes, I've got a vest and triangle as well.
Looking for flares was what lead me to finding those LED beacons. They essentially act as a flare, but you can magnetically attach them to the vehicle or hang them from something. They are reportedly very bright and can switch between steady and flashing.
I did see that on a couple of lists as well. Thanks for the suggestion!
