Garmin PowerSwitch
Oly_Bronco
WA
Anybody looking to add aux switches that either did not get any from the factory or need more check out the Garmin PowerSwitch. I got my kit from Blaze Off-Road and they have a bracket that mounts the PowerSwitch and a ground bar to it. I also added the SDHQ battery terminal kit also available from Blaze Off-Road. Super clean setup!
https://blazeoffroad.com/collections/2021-bronco/products/ford-bronco-garmin-powerswitch-kit
https://blazeoffroad.com/collection...raptor-sdhq-built-billet-battery-terminal-kit
Ford Bronco Garmin PowerSwitch IMG_0442
Ford Bronco Garmin PowerSwitch IMG_0443
AzGrayHeritage
Keevan
Georgia
Azure Gray Heritage 24
How is this working out for you? I'm very curious about this.
Oly_Bronco
Oly_Bronco
WA
It works awesome. Currently I have just my @Baja Designs LP6's x3 on one switch and the backlight for all 3 on another of them. I also use one of the control inputs for the Garmin Powerswitch so when my headlights go on it will turn the backlight of my LP6's on. I have the @SPVPARTS harness that connects to the headlight that can be used to power the backlights. I split that harness so one side connects to my backlights of my LP4 on my A pillar and the other side connects to the control input. I will eventually have an S8 light bar that will also connect to the powerswitch and because I have the control input its backlight can also be turned on when the headlights go in. When I do that I will get the Blaze Off-Road Backbone Wiring Harness that will connect to the powerswitch.
AzGrayHeritage
Keevan
Georgia
Are using Android Auto or Car Play as your interface or the mobile app?
Oly_Bronco
Oly_Bronco
WA
