Galloping sounds
SATX
Jose
Bronco G2&G3&G6
After exiting and closing doors, my Bronco makes a “galloping” or thumping sound. Sometimes multiple times. Is this normal?
I didn’t notice it prior to installing an amp and new speakers so many it was there but much more faint.
PWillette
Parrie
Maine
Galloping you say? Trying to get out of the stable maybe?
Unfortunately mine has yet to be delivered so have no real world experience but have heard of a few people hearing strange noises after shutting down but most were the exhaust/cat cooling. Can you pinpoint were the noise is coming from.
JohnnyBronco
Pennsylania
X4
It's the spare "part" from the other thread rolling around. Now if it whinnies and front end jumps in the air, get back in and yell "Hi-yo, Silver"
No, I hear a sound, too. It's the windows going back up. If you do not hear the window the door is not fully closed
SATX
SATX
Jose
Bronco G2&G3&G6
It’s not the window. It sounds like 4 sets of “trots”. And no I’m not imagining it. I was trying to post the iPhone MOV but it doesn’t seem to play after I post it. I’ll try uploading again.
wrbix
VA and FL
LR Def90, F250 7.3, Caterham 7, LR Series III, etc
Sure sounds like a servo of some description resetting or trying to ?close. From what part of vehicle does it emanate?
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
I hear it too. Figured it was just some normal equipment boot up or shutdown noises.
SATX
SATX
Jose
Bronco G2&G3&G6
The sound appears to be coming from audio, speakers. I recorded that by leaving the phone in the Bronco before I exited and closed the door.
wrbix
VA and FL
Try turning audio volume way down before shutdown?
SATX
SATX
Jose
Bronco G2&G3&G6
Yes, at this point the audio controls are no longer affecting the volume as the audio is supposed to be off so the volume level is constant. But I can increase the strength of the sound by increasing the gain on the amplifier…basically amplifying it more.
wrbix
VA and FL
So, sounds like some servo shutting down is sending noise to audio system……sorry, that’s all I got.
OEM audio or some additions? Something needs a better ground or more shielding, I’d guess.
Pseudoko
Vince
Chino, CA
My 2 Feet
are you sure you didn't have this guy following you around?
Ford Bronco Galloping sounds montypython
