Fuse Info / Help?
TenSeven
Huntington Beach, CA
2022 Bronco Badlands
So my rear 12v power socket died and I finally figured out that it is powered via underhood fuse #33. I pulled the fuse and sure enough it was popped.
No big deal, right? The thing is, I have never dealt with this type of fuse before. Neither the guy at the parts store nor the parts counter guys at HB Ford* knew what to call them.
I need to buy an assortment of them, what are they called???
Ford Bronco Fuse Info / Help? Bronco_Fuse_20A_01
* - Special thanks to the HB Ford parts guy as he was kind enough to give me one free of charge. Thank You!
*** EDIT ***
I think I found the answers, I just didn't look hard enough:
https://www.bronco6g.com/forum/threads/2021-bronco-fuse-types.44742/
jh3113
Jake
Phoenix
Subaru Outback
Did you find out how it blew or was it just a bad fuse?
TenSeven
TenSeven
I'm not 100% positive, but am fairly cartain the fuse said "Nope!" when I was trying to add a power tap to the 12v socket wiring.
The tap I tried to use did not look to be the best quality and I should have known better. Lesson learned.
Kyle
San Francisco
Do you have a photo of which fuse it was in the panel? New to all of this, and just had my 12v stop working for similar reasons. Thinking I also blew a fuse.
