Functions tied to the Auto Transmission only?
zuke
Stafford VA
If the trail turn assist is actually done completely right, and I don't know if it is at this point, then it would need to
unlock the rear axle
put the rear axle in neutral in the transfer case
apply the brake on the inside rear wheel for turn
reverse all that when the wheel is straightened out
should be possible to do all that with the manual just as easily as the automatic, but since a lot of the other tricks won't work without an automatic, I'd bet Ford won't implement this one either..
mrcx
Grapevine, TX
'67 Camaro
I'm sorry if you meant for the manual trans., I don't know if that would be a possiblity.
I have a bookmark for a page that duscussdd the app remote start:
https://www.bronco6g.com/forum/threads/base-model-bronco-thread-?.1828/page-57#post-145913
Although, I think one could go to a shop and get remote start on a manual trans. car like a best buy or a car audio place that does alarms and such.
A story to go along with that. I know someone that did put remote start on their stick car. They were parked in a parking garage facing a wall ... in first gear.
... remote start ... found the car into the wall.
Don't know if the app will start a manual equipped car; that would be an experiment for those to try later when they get theirs
... maybe in an open field
... away from cars
... people
... and importany walls ??
Here is a system that will work with manual. https://www.compustar.com/remotes/pro-t12-w-lte/?systemId=70
