Front trail camera options
MPTB
Pat
Wisconsin
My front camera took a hit and didn't survive. A ford replacement camera is about $260. Is there a cheaper off the shelf camera that will work as a plug and play replacement? I don't really care what shape or size it is as I'm sure I can make a winch bracket mount for whatever work.
Bikeric
Tulsa
2022 Badlands LUX on 37's
I just checked prices and OH BOY!! I can't believe they charge that much for the camera. Sorry I have no advice for you as far as an alternate.
I do have a question though. Did you relocate your camera from the grill to in front of your winch? Is that why the camera took a hit? If so, I'll be leaving mine in the grill.
MPTB
MPTB
Pat
Wisconsin
Relocating it in front of the winch does make it more vulnerable but damage happens when offroading and this was just bad luck.
ColoradoBadsquatch2044
Tyler
2017 F250 Lariat 4x4
Was the $260 just for the camera or did that include labor? When I had an f250 I replaced the camera and it was in the $300s so this is easier to stomach. I’ll eventually need to replace mine since it’s got a scratch on the plastic cover right in the middle of the field of view.
MPTB
MPTB
Pat
Wisconsin
Just the camera.
Tricky Mike
21 Bronco
I can't name one specifically, but our camera uses a common Fakra Z cable connector so I'd gamble on a cheap one off amazon with matching connector. At least with Amazon you can always return it easily if it doesn't work. Or you can get a Fakra Z to RCA adapter and plug in any cheap back up camera and maybe it will work.
MPTB
MPTB
Pat
Wisconsin
That was the plan but unfortunately I can't seem to find a fakra z backup cam. Most cameras also have separate power and ground circuits which isnt the end of the world but adds to the screwing around just to see if it works.
