FPP tuner install King/Snohomish Counties
br04h
Noah
Kirkland Wa
‘81 FJ60, ‘17 E400, ‘19 Ducati CR, ‘22 Bronco
Thank you! So they had no problem installing the tune with a tuner you supplied and purchased somewhere else?
If so, I'm going to be giving them a call soon. While it's easy enough to do yourself, I don't want to be effing around with Ford if a warranty issue comes up with anything.
Yeah- they had no problem doing it even though I bought the tune elsewhere.
I did it for the same warranty reason
Freedom5
Freedom
Snohomish Washington
Classic mini cooper
Harris Ford in Lynnwood will do it
Overcooked
WA
2023 2D WT, 2021 BMW 540, 2024 BMW M8, 2021 X7
In this case I actually suggest you bring the tuner, or at least ask the shop to register the tuner under your name. So when there’s an software update you can download it yourself
Overcooked
WA
FYI evergreen ford can do it for a reasonable price. You are welcome to bring your own ProCal tool as well, they don't care. You can also create your FP account and give them the account name and password and they will do it using your account. And if there are any future update you can update the tune yourself.
Just placed an order through Lethal for the $599 black Friday deal ;)
Poppavein
Redmond, WA
Harleys, Ducatis, 2024 Bronco
Do you get to keep it in case you need to do an update later yourself? Say, you put on bigger tires.
