FOX RACING: AVAILABLE HERE AT LETHAL PERFORMANCE
LethalPerformance
Jared
South Florida
www.lethalperformance.com
Hey All,
Proud to announce the entire FOX Racing Shock line-up for the 2021 Bronco is now available for purchase here at Lethal Performance.
With 2 Series choices for those looking for slight vs moderate lift, the FOX Performance Elite shocks give amazing ride and increased performance for your Bronco to ensure you get the max out of every bit of Bronco.
FOX Performance Elite 2.5 Series shocks for the new full-size Ford Bronco are designed and engineered by off-road enthusiasts to enhance comfort, maximize articulation, and increase compliance in the dirt. You also gain 20% more travel over the stock shocks.
FOX's progressively wound springs provide extra clearance and movement to unlock your Bronco’s entire range of usable travel in both jounce and droop positions. These springs were specifically chosen to compliment the Bronco’s IFS design to offer a uniquely soft ride and better control through rough terrain.
The shocks’ 2.5-inch aluminum bodies and external reservoirs efficiently dissipate heat by increasing internal oil capacity, while the remote reservoirs with Dual Speed Compression (DSC) adjusters are strategically mounted to clear aggressive mud tires and leave space for aftermarket skid plates and bumpers.
Easily adapt your shocks for load, environment, and driving style using the DSC adjusters as the large capacity dampers manage stability through all types of terrain. Additionally, you have a generous amount of preload adjustment to maintain your Bronco’s ideal ride height while supporting a wide range of essential added gear.
FOX shocks provide the versatility required to navigate backcountry terrain on the weekend and tackle your daily commute to remain comfortable and in control.
Features:
- 2.5” impact-extruded and CNC-machined 6061-T6 hard-anodized aluminum body
- Application-specific, custom progressive springs
- 7/8” hard chrome-plated steel shafts
- Vehicle-specific valving to maximize performance
- 2.5” smooth bore and honed seamless alloy reservoir with Dual Speed Compression (DSC) adjuster
Benefits:
- Unlock all travel available in jounce and droop positions
- Maximize comfort and control through any terrain
- Remote reservoirs are mounted to clear larger tires and aftermarket parts
- Maintain optimal ride height with wide-range preload adjustment
- Provide a 3” lift for Sasquatch Bronco and a 4” lift on a non-Sasquatch equipped Bronco
- Soft, progressive springs enhance articulation and increase stability
DUAL SPEED COMPRESSION (DSC) ADJUSTER
Add remarkable versatility and precise tuning with Fox's DSC adjuster. A simple twist of either two adjuster knobs allows 10 separate low-speed and 12 high-speed compression levels. Included new black anodized aluminum reservoir increases cooling efficiency.
Fox Racing 2.5 RR Elite DSC Front Adjustable Coilovers (2.5-4.5" lift) (2021+ Ford Bronco 2-Door) 883-06-192
Extended23.720
Compressed17.940
Travel5.780
Top MountOEM
Bottom MountBar Pin
*Requires Upper Control Arm
(Sold as a PAIR with all needed mounting hardware for both shocks and reservoirs)
Check them out here below!
2 Door Sasquatch and Non-Sasquatch
4 Door Sasquatch and Non-Sasquatch
Fox Racing 2.5 Remote Reservoir Elite DSC Front Adjustable Coilovers (2-4" lift) (2021+ Ford Bronco 4-Door) 883-06-195
Fox Racing 2.5 RR Elite DSC Rear Adjustable Coilovers (2.5-4.5" lift) (2021+ Ford Bronco 2-Door) 883-06-193
Extended26.420
Compressed19.440
Travel6.980
Top MountOEM
Bottom MountBolt
Fox Racing 2.5 Remote Reservoir Elite DSC Rear Adjustable Coilovers (2-4" lift) (2021+ Ford Bronco 4-Door) 883-06-196
Have questions or want to get something on order? Feel free to reach out to me or any one of us on here, shoot us a call at 561-753-8105, or shoot us an email at support@lethalperformance .
Joe Rocchio / [email protected]
877-2-LETHAL | lethalperformance.com
GloNDark
Reno NV
1973 Bronco Ranger & 2021 Bronco First Edition
What's the lead time on getting them if ordered? I tried to order from Camburg and they told me 8 to 10 months.
LethalPerformance
LethalPerformance
Jared
South Florida
From what my distributors are telling me, roughly around late March 2022 on orders placed now.
Jason hamilton
Knoxville TN
Tahoe
On the 4 door option is the lift height adjustable? I have a non-sas and I am looking to go up 2-3 inches.
