Fifteen52 Wheels - AVAILABLE HERE AT LETHAL PERFORMANCE
LethalPerformance
Jared
South Florida
www.lethalperformance.com
Hey All,
Fifteen52 Wheels are now among the great brands of wheels we have available for the 2021+ Bronco here at Lethal Performance .
TURBOMAC HD & CLASSIC
Ford Bronco Fifteen52 Wheels - AVAILABLE HERE AT LETHAL PERFORMANCE 0k14hS4sRK_lbLsityZIbCzJtr6EBEBqKJc3DWmMNxT2rvKq0r
The 17x8.5 Turbomac HD features a simulated beadlock ring with stainless-steel hardware for corrosion resistance. Also giving it that off-road, rugged look that your build is after.
Utilize 60-degree tapered lug seats and will work with any standard lug hardware.
Offset - 0
Hubbore - 106.2
Weight (lbs) - 26.32
Max Load Rating - 2500
Rim Construction - Cast
Rim Material - Aluminum
Lug Nut Seat Style - Conical Seat - 60 Degree
Available in Block Bronze & Asphalt Black.
Ford Bronco Fifteen52 Wheels - AVAILABLE HERE AT LETHAL PERFORMANCE 7hJzvFfYhFUcu3knWKyPkoy8MG79QAEKGGgrJCTNqIlABHNttg
Check it out here below!
Magnesium Grey
fifteen52 17x8.5 (6x139.7TURBOMAC HD Wheel, 4.75 BS in MAGNESIUM GREY (SATIN BRONZE/SATIN BLACK RING/BLACK HARDWARE) - THDMG-178569-00
Block Bronze
fifteen52 17x8.5 (6x139.7TURBOMAC HD Wheel, 4.75 BS in BLOCK BRONZE (MATTE BRONZE/SATIN BLACK RING/STEEL HARDWARE) - THDBB-178569-00
Asphalt Black
fifteen52 17x8.5 (6x139.7TURBOMAC HD Wheel, 4.75 BS in ASPHALT BLACK (SATIN BLACK/STEEL HARDWARE) - THDAB-178569-00
TRAVERSE
Ford Bronco Fifteen52 Wheels - AVAILABLE HERE AT LETHAL PERFORMANCE BUc9Nf_zP-ov-fog75GLVNMYNjtK2XFSwSRahXB8tZH8qjdyvd
Offset - 0
Hubbore - 106.2
Weight (lbs) - 29.88
Wheel Cap - C52T-L-BB
Also available in Asphalt Black.
Ford Bronco Fifteen52 Wheels - AVAILABLE HERE AT LETHAL PERFORMANCE I2jRLTPFxKz76Sty2K57_0Z-3Z5V_GxVqjHY5aurFV6BJINs1P
Check them out below!
Block Bronze
fifteen52 17x8.5 (6x139.7TRAVERSE HD Wheel, 4.75 BS in BLOCK BRONZE (MATTE BRONZE/SATIN BLACK RING) - RHDBB-178569-00
Asphalt Black
fifteen52 17x8.5 (6x139.7TRAVERSE HD Wheel, 4.75 BS in ASPHALT BLACK (SATIN BLACK) - RHDAB-178569-00
ANALOG HD
Ford Bronco Fifteen52 Wheels - AVAILABLE HERE AT LETHAL PERFORMANCE UdeB5tO5E6awGGfk7pE5xLB-iTjoDtZmSj-AWk-nRnBxqhUjgK
Offset - 0
Hubbore - 106.2
Weight (lbs) - 27.5
Max Load Rating - 2500 LBS
Wheel Cap - C52T-L-PG
Ford Bronco Fifteen52 Wheels - AVAILABLE HERE AT LETHAL PERFORMANCE JdVs8lab1-E5Z67PwqfzKroBbHUgm6pwx--pfxDcjMifQI8OZG
Also available in Asphalt Black and Peak Grey.
Classic White
fifteen52 17x8.5 (6x139.7 ANALOG HD Wheel, 4.75 BS in PEAK GREY (CLASSIC WHITE) - AHDPG-78569-00
Asphalt Black
Peak Grey
fifteen52 17x8.5 (6x139.7 ANALOG HD Wheel, 4.75 BS in PEAK GREY (GLOSS GREY) - AHDPG-78569-00
Of course, if you have questions or want to get something on order, feel free to reach out to me or any one of us on here, shoot us a call at 561-753-8105, or shoot us an email at support@lethalperformance .
Joe Rocchio / [email protected]
877-2-LETHAL | lethalperformance.com
Ford Bronco Fifteen52 Wheels - AVAILABLE HERE AT LETHAL PERFORMANCE yB3dgJWy0z7KsdKX69_aKWiHY8zenl7C2SF3ZRoS-W8lfOeI9a
