ForScan and windows 10 or 11
  • Thread starter Deleted member 32220
  • Start date
  • Watchers 0
Guest
Does anyone have any experience with either of these 2 O.S. working? I will be using the obdlink ex dongle
shoelessjoe
2013 Chevy Cruze
Pretty sure it works with Windows 10, not sure about Windows 11. Doesn't look like it works with Windows 11.
ColeTrain84
Cole
Minnesota
'22 Bronco Badlands
i have the same dongle and a windows 11 laptop i just bought. i'll let you know when my Bronco shows up or when the wifes Explorer gets here and i start looking into them :)
da_jokker
Jeep Wrangler JKUR
And if for some reason it doesn't run in a Windows 11, you can always use compatibility mode to make it go all the way back to Windows 7.
5GENIDN
Joe
Idaho
SO your one and only post resurrects a 2 year old thread so you can shill for "affordable keys".... I am not clicking on that.... Mostly because you own a Dodge from Switzerland ....
HCGxKaLiBeR
CT
2025 BMW X2 M35i
Windows 11 is essentially Windows 10. It will work if it it works on Win10.
The big compatibility gaps are only between Win XP, Win7, Win10.
Karl_in_Chicago
Karl
Chicago
When it comes to using FORScan with Windows 10 or 11, it's important to ensure compatibility with your operating system before diving in. Whether you're sticking with Windows 10 or thinking about making the jump to Windows 11, checking compatibility with tools like FORScan can help ensure a smooth experience. If you're curious about what Windows 11 has to offer, you might find some helpful insights on https://digitalchillmart.com/product/windows-11-pro-32-64-bit/ .
Forscan runs fine on my Win 11 Pro Dell Latitude (refurb); delivered as a Win 10 Pro and then upgraded to 11 (which I regret, but that's another story). So that's my $0.02 for anyone that doesn't want to go nosing around a website that sells discount license keys to find out more.
Smells like a ChatGPT bot... low post count, necro bump with random article of semi-pertinent generic info, with a dubious purchase link.
LouisDixon
BMW
I used the OBDLink EX dongle on Windows 10 a while back, and it worked fine for me. Windows 11 should also support it, but I’d check if the drivers are updated for that OS. I ran into issues when my system didn’t recognize my dongle after an update. I found out a clean reinstall or a system reset sometimes fixes such problems. You can find instructions on how to reset Windows 11 here: https://operatingsystems.info/how-to-factory-reset-pc-windows-11/ . That might help if you run into trouble.
