- Eric
- Jul 9, 2020
- 195
- 4,365
- 6,876
- Ontario Canada
- 2 door Squatched
- Badlands
- Banned
- #331
This image must be the modular hard top??
i believe it is the molded-in-color non-removeable topThis image must be the modular hard top??
No way! Look how it over hangs outside the window frame... Chunkyi believe it is the molded-in-color non-removeable top
pretty sure they'll all be remove-able. Where is a rumor for a non remove-able roof coming from, or am I misreading what you are saying?No way! Look how it over hangs outside the window frame... Chunky
And how it comes up to the windshield frame...
Maybe... I dunno. Doesn't look right for a non removable roof. If it is, I'll pass on it.
This pic is what I believe to be non removable roof.
If it's a non removable roof, why is it composite and not painted with the rest of the truck?No way! Look how it over hangs outside the window frame... Chunky
I'll rephrase... Modular roof. I think this is just with removable quarter panelsIf it's a non removable roof, why is it composite and not painted with the rest of the truck?
I think the rollbar/frame will be the same on all of them. just a matter of what top is over it. It would make the most production sense to do it that way.Which also begs the question... Will on non removable roof have a roll cage? Likely not I'm guessing...
And probably a chunk cheaper than any of the other roof options. But in what trim? All trims?
Probably the route is go... Fixed roof
This makes sense... As even the fixed roof is molded plastic ??I think the rollbar/frame will be the same on all of them. just a matter of what top is over it. It would make the most production sense to do it that way.
I just hope it is possible to remove it. I really want a truly open air like the EB, with a simple rollbar right behind the seat.
This is the first I'm hearing about a permanent, fixed, non-removable roof???Will on non removable roof have a roll cage?
In the options leak list... That's how I interpret it anyway.This is the first I'm hearing about a permanent, fixed, non-removable roof???
Yes, all models will have the roll cage, the lawyers and regulations require it.Which also begs the question... Will on non removable roof have a roll cage? Likely not I'm guessing...
not sure that interpretation is correctIn the options leak list
All other roofs are either modular hard or dual hard/soft.not sure that interpretation is correct
