Ford Performance Winch - Connecting the Dots
sanford
Ross
Columbus
Chevy Silverado, Subaru Crosstrek, Bronco
The newly published Bronco Accessory Portfolio has one line about the proposed Bronco winch:
Ford Bronco Ford Performance Winch - Connecting the Dots 1610653856033
Past Guides [https://www.bronco6g.com/forum/attachments/2021-bronco-accessories-pricing-pdf.58623/] have shown two winches:
Ford Bronco Ford Performance Winch - Connecting the Dots 1610653978563
(a fairly clunkily solution that hides the Bronco logo on the grille)
AND
Ford Bronco Ford Performance Winch - Connecting the Dots 1610654025835
a nicer one that somewhat matches the B&P tool:
Ford Bronco Ford Performance Winch - Connecting the Dots 1610654185103
Assuming all these block the front trail camera.
The NEW Guide [https://www.bronco6g.com/forum/threads/2021-bronco-accessories-list-pricing-part-numbers-pdf.11037/] model number (M-1821-B) at least matches the Ford Performance by Warn Winch. All the photos seem to match the ZEON 10-S WINCH on their website, but the description calls out the ZEON 10 WINCH. U725 is the old code name for the Bronco.
I can't find anything about a standalone winch mounting system, so we can bring our own winch. Think we have any more details for the ordering starts next week?
MadMan4BamaNATL
Ray
Atlanta
By the way, right now B&P says it's Zeon 10-S and 100ft syntectic. It still has an old description with 80' galvanized steel wire, but I am 98,5% sure it's gonna be 10-S in real :)
Should be a 100ft Spydura line. Steel cable isn’t terrible, but I don’t want any. Synthetic can be high maintenance when it gets dirty or muddy, whereas steel seems to work fine, but both should be cleaned after a recovery.
evgenyvasenev
Evgeny
Gig Harbor, WA
www.instagram.com
Ford Bronco Badlands
sanford
sanford
Ross
Columbus
New winch specs: https://www.warn.com/zeon-10s-winch-89611
Choose your way to conquer the terrain. The ZEON 10-S is tough enough to tackle anything you will, with a look that is advanced, capable and strong. Muck-busting sealing keeps out everything but the good times. Add a hyper-durable cast-aluminum housing, satin-black finish, and 10,000 Pound single-line pulling capacity and, well, you've got a workhorse unit you can trust for years to come.
  • 10,000 Pound (4536 Kilogram) Single-Line Pulling Capacity
  • Includes 100 Foot Of 3/8 Inch Warn Spydura Synthetic Rope, Which Includes A Temperature-Resistant Sleeve On The First Layer, A Ballistic Nylon Sliding Sleeve And A Polished Aluminum Hawse Fairlead
  • Convertible Control Pack Can Be Attached To The Winch Or Remotely Mounted, Allowing For Various Winch Mounting Options And Looks
  • New-Design Planetary Gear Train And Series-Wound Motor Deliver Fast, Quiet, And Reliable Pulling Power
  • Satin-Black Powder-Coated Finish With Stainless Steel Fasteners And Clutch Lever Looks Great And Inhibits Corrosion. Improved Winch Sealing To Keep The Elements Out
  • Large Diameter Winch Drum Reduces Rope Wear, Is Light Weight, And Has An Integrated Rope Anchor For Easy Rope Installation
  • Limited Lifetime Warranty for Mechanical Components. Limited Seven (7) year warranty for Electrical Components.
2Jeeps&PatriotX1
Denver, CO
Probably wont get it on the wife’s first bronco as dont want to hold up the MY21 build. For her MY22 we’ll get it most likely if nothing aftermarket is out yet.
ResidualGenius
Zach
Denver
drive21bronco
North East USA
2021 Bronco Black Diamond
I’m not sure if it would hold up your 21MY Build as it is an accessory and would be shipped to the dealers parts dept separately. I could be wrong though..
rtaylor
R
ID
19Raptor, 22Bronco
Don't forget that it is probably late availability.... Q3. Perhaps meaning they haven't figured it out completely yet. Hopefully, low profile for less camera impact and maybe an integrated safety relay to prevent crash fires.
Ford Bronco Ford Performance Winch - Connecting the Dots 1613095977639
I am hoping that they sell the mount separately later...
evgenyvasenev
Evgeny
Gig Harbor, WA
www.instagram.com
It will not hold you. It's a dealer accessory with dealer installation fees.
evgenyvasenev
Evgeny
Gig Harbor, WA
www.instagram.com
Yeah, I hope they will figure out that "camera" problem.
2Jeeps&PatriotX1
Denver, CO
Probably right but I also dont see the point if its a late arrival. Might as well wait for it to come with Bronco #2. No reason to pay for it if it wont get used on Bronco 1.
the super duty tremor guys waited close to a year to get their winches from Ford after they were announced and the truck were produced.
ohvrider
San Jose, CA
2019 Ford F-150 Raptor
The ford solution will always have the camera problem. To fix that get an aftermarket bumper that mounts the winch inside the bumper. Also mounting winch on top of bumper used to make my wrangler overheat because of the restricted air flow to radiator.
