Ford Accessory Bronco Console Vault Does Not Fit
rothy-j
Josh
Nashville, TN
2021 First Edition
Hello everyone - new bronco owner here. I picked up my 2021 Wildtrack First Edition a little over two months ago, and I've been going a little off the deep end with accessories. One I was looking forward to adding was the console vault. I've been hesitant to pull the trigger but found one online (eBay) from a highly rated dealer just a couple of states over. Good price and package looked to only be opened for pictures.
It arrived a couple weeks ago - I had time last weekend to install but something's off. According to the part number and a sticker on the underside of the latch, it's a Ford product (even every video I look at has the same design), but this thing will absolutely not fit in my console. I wanted to see if anyone knows of two/various models for this product. Everything I read (even on Ford Accessories site) shows this as the model that fits - there's just no way.
Anyone else have/had this experience?
Ford Bronco Ford Accessory Bronco Console Vault Does Not Fit 01
Ford Bronco Ford Accessory Bronco Console Vault Does Not Fit 02
Ford Bronco Ford Accessory Bronco Console Vault Does Not Fit 03
rothy-j
rothy-j
Josh
Nashville, TN
2021 First Edition
Gave to insert it at an angle apparently. Go to 2:55 here
This is the video I should have watched first....and I watched a few. This is correct and - just like @Alsvior suggested, too.
TIL - I'm not a professional accessory installer, but I seem to know where to look for help. Thanks y'all.
Easy-v
U S A
BadSquatch
That looks just like mine.
I installed mine a few weeks ago, but if I remember right, the cavity in the console is bigger than the opening. Try dropping it in diagonally, then turn it into place.
edit: but maybe I should look at mine again when I get home…
This
I ended up calling suport and you have to angle it in. Felt stupid afterwards how easy it went in.
Swallace
Sean
N. Andover Ma
Toyota ,Gmc and Subaru
This
can you still put the key fob in if you install the safe?
