FM Static
Jamie
On,Canada
2021 Bronco Black Diamond
I installed a Rough Country bull bar with lights I hooked up to the AUX 1 switch and when I turn them on I get static on my FM radio stations. Any ideas?
Paul Gagnon
Paul
Sherwood Park, Alberta, eh?
'79 Mustang, '92 Explorer, '10 F-350
Are you sure it is caused by the lights? I get poor FM reception quite often and I have no added accessories.
Headsong
Well, if he didn't get it before.....
Probably need one of them thingies we used to use in the old days, connected to the antenna maybe? Someone will remember what they're called.
kodiakisland
Arkansas
Check your ground or ground somewhere else to see if it helps. Some LEDs are worse than others.
Several threads about this in the lighting forum.
Headsong
Ground_zero298
Scs michigan
Mlarv
TN
2023 Bronco/ 2022 F150/ 1968 Mustang
Are they LED. If so this is the issue. LED's send out a lot of electrical noise, check to see if your key fob works from the front when they are on.
Replace them with a Good LED light, check grounds, maybe a chock on the power wire (but I doubt that would work).
