Fluid Specs/Capacities Provided Here
swamp2
Is there a manual for the Raptor, paper or digital that is different than the non Raptor models? Seems different enough that it would require a lot of paper inserts to cover everything.
Along these lines, I don't see a list of Raptor specific fluids (if required). Minimally one would want such a list also for the capacities. Bare minimum engine and axles absolutely different capacities. Coolant and brake fluid capacities also likely different.
Owners - please let us know what there is in the printed materials.
Anyone - post digital if available.
Update (from another member who got official Raptor pdfs (not manuals) from Ford and a wee bit of extrapolation from other Ford docs)
  • Engine
    • Oil: Motorcraft 5W-30 Synthetic Blend
      • Initial fill volume: 8.3 qt
      • Service fill (w/ filter): 7.0 qt
      • Service (w/o filter): 6.5 qt
      • Extreme cold (-22.0°F) alternative: SAE 0W-30 Synthetic Blend
  • Spark plug: Motorcraft 12405
  • Spark plug Gap: 0.028-0.031 in
  • Coolant: Motorcraft Yellow, 12.4 qt
  • Transmission
    • Rear diff: Motorcraft SEA 75W-85 Premium Synthetic Hypoid Gear Lubricant, 3.97 pint (=1.99 qt) (to bottom of filler hole).
    • Front diff: Motorcraft SEA 75W-85 Premium Synthetic Hypoid Gear Lubricant, 0.87 qt
    • Transfer case: Motorcraft MERCON LV Automatic Transmission Fluid, 1.6 qt
    • Transmission: Motorcraft MERCON ULV, 13.1 qt, Drain plug torque: 52 ft-lb
  • Brakes: Motorcraft® DOT 4 LV High Performance Motor Vehicle Brake Fluid
If you suggest any additions or corrections, post and/or PM me and I will update.
Crazycactus
Alan
Ohio
1990 F250, 1993 Bronco XLT, 2013 F-150 Platinum
Yes, there are Raptor specific manuals/ guides in a Ford Performance manual cover that came with mine.
