Few Christmas gifts installed this morning.
Deleted User 5719102
Who's
On a Lake
22 2dr
There is but it’s tight, I pulled the grab handle off and the panel beside it off to ease access for routing a dash cam cable. Getting that A pillar panel off is no easy task.
I did not take the A-pillar cover off due to airbag is there. I routed mine in between the base of the A-pillar cover and dash. I took only the center cover off below the A-pillar, then pushed it in between the dash and A-pillar trim, it fit right in. Once I had it pushed in up to the winshield, I pulled on cable and it went right into the back of A-pillar cover. Then I pushed it in behind the A-pillar cover up along the windshield, all the way up and around the top to the center overhead console. It went right in. Then once I got to the center overhead console, I fed the rest of the cable in at that one spot. Pull the sunvisor down and I then pulled down on the upper side of that trim piece at the t-top at the same area where I stuffed the remaining cable and used a cut off piece of cloth hanger and snaked it up and out the top.
BroncoWTFAN
NJ
MachE FE & BL SAS 22
Ford Bronco Few Christmas gifts installed this morning. IMG_20221225_182134
Spot on!
I ran a wire for my dash cam the exact same way.
NVCowboy
William
Henderson, NV
2002 F350. 2022 Big Bend (Sasquatch)
Looks good. I feel like I need to hit ya back when my Black Diamond finally gets here and we can swap my blue handles and a/c registers for your Grey ones, but that might be too much of a good thing. LOL.
Who's
On a Lake
22 2dr
Sounds good to me. I've been looking to buy the blue ones.
