Fender flare problem - too easy to remove / be stolen ?
Mdeamon
Hyundai tucson
I am worried that people will steal them because they are too easy to remove.
It like hubcaps ... last time I rent a car in Miami someone steal the hubcaps on my rental.....
I hope they have better option ... I rather take little bit more time to undo then dealing will stolen fender flare....
Vigor
Heaven on Earth
If people want to steal something, they will find a way to do it!
Be it fender flares, wheels, tires. Heck even the safari bar might get stolen.
A risk that has to be considered. You can mitigate this risk with an alarm system
Bronc-O
Phoenix
2021 Lincoln Aviator
Not everyone is going to know how they are removed. If it happened, I'd be inclined to suspect another Bronco owner was the culprit.
North7
North Texas
SUV
I’m sure there will be a solution to replace the quick release tabs with something that requires a tool.
Yes, previously invented for the Bronco and Trademarked by @North7
Bronco Flares Security Pins:
Torx security screws, aka, Barrel nut/screws, are common and available in multiple lengths.
Ford Bronco Fender flare problem - too easy to remove / be stolen ? Binder-Post-GRIP
JGuske23
Justin
Kalamazoo
2019 Jeep compass
What does everyone think people are going to do with all of these stolen fender flares?
How many non-Bronco enthusiasts will know the flares are easily removed?
How is this an issue?
Exactly, people steal things to resell or keep themselves. The market for stock fenders are going to be minimal at best ha. And I think it's safe to say NOBODY wants to steal the aftermarket options we've seen to date
Bronc-O
Phoenix
Right, just like I said 5 posts back. :) Bronco owners would be the most likely suspect.
Scohin
Ford Fusion
They're plastic so no one is going to yank them for scrap, I'm not worried
Ryuk
PA
2021 Ford Ranger, 2023 Ford F-150
Just don't run with them, and when you get pulled over, you can tell the Po Po that they were stolen and you have another set ordered, but they have not arrived yet due to the part constraints. Then show Mr. Po Po the picture of the stuck cargo ship and be on your way.
Mdeamon
Hyundai tucson
When they stole the hubcaps on my rental car
It cost me 500$ to replace before I return the rental ....
Plastic or not it a commodity if a lot of people steal them because it easy ... you will have demanded to replace them....
Fatdaddy
I’m sure there will be a solution but in the interim I imagine it’ll become a fun game for the yutes the steal them.
Ford Bronco Fender flare problem - too easy to remove / be stolen ? 1616955378254
  • Like
Reactions: abe
Norm A.
Norman
Just one or two on each flare should do the trick 😉
TomD9807
Thomas
2016 F-150 / 2016 Infiniti Q50
Seeing the Demonstrations on how easy it is to modify the Bronco, How long will it be before you come out of Walmart or some store and find that someone took your Fender Flares in the 5 minutes you were away?
