North Carolina Factory Hardtop 4dr
Brandonj83
Brandon
F150 Raptor
Decided to hang on to it for now.
CyberOrange
Trina
Blairsville, GA
Hey! Would that top fit a 2021 Outer Banks? That is a full hard top for a four door correct? Where are you in North Carolina? I'm in North Georgia.
Brandonj83
Brandon
F150 Raptor
I’m in Southeastern NC. Probably 5.5 hours away. I’m 5 hours from Clemson SC. It should fit a 21’ no problem as long as it is a 4 door.
TheShark
Correct me if I wrong but didn't the '21 Bronco soft tops not come with the prep kit for the hard top? I thought they didn't include that till at least '22.
CyberOrange
Trina
Blairsville, GA
So that would be an additional need to possibly make thus hard top fit my 21? Can anyone tell me where/how to find out if the 23 will fit the 21? Sorry dumb lady Big Buck owner here.
Brandonj83
Brandon
F150 Raptor
I would think the only parts you need are the brackets that the mid top panel clamps down to and the bolts that hold the rear section to the rear quarters. The front panels clamp into the same brackets the soft top clamps into.
Brandonj83
Brandon
F150 Raptor
Ford Bronco Factory Hardtop 4dr IMG_2247
These two brackets secure the mid panel and the back of the front two panels.
CyberOrange
Trina
Blairsville, GA
I have a mechanic lined up for the install once I find the compatible top. Thought of buying an aftermarket but the shipping alone was about $1000. Thank you again
VetHS
Dale
Shenadoah VA
2023 Bronco
Are you including the two front panels also? Did not see in pics or description
Brandonj83
Brandon
F150 Raptor
Yes. This is for everything minus a few bolts that I had to use to put the soft top brackets on.
I only have the front panel storage bags though.
Brandonj83
Brandon
F150 Raptor
No longer for sale.
