Exhaust Systems
B-rad351
Brad
WV
2024 Bronco
Does the 2.3 muffler/dual tailpipe assembly fit the 2.7? I’ve seen in some ads they are the same but then see them as different part numbers in others. Ford Performance has the 2.3 listed for less $$ than the system for the 2.7.
Confusing…?
JL8jeff
Ewing, NJ
The tailpipe hanger is in a slightly different location with the stock exhaust on the 2.3 vs the 2.7. So some of the aftermarket is specific to the 2.3 or 2.7, while some of them offer an extra hanger mount so it works on trucks with both engines. I would post up the specific system you are considering to see if someone can tell you if it fits both setups.
B-rad351
B-rad351
Brad
WV
2024 Bronco
Ahh, I understand. I’m looking at the two systems from Ford Performance. Sounds like I should stick with the one for the 2.7. It does look like the one tailpipe hanger is in a smidge different place between the two.​
Ford Bronco Exhaust Systems IMG_6050
Ford Bronco Exhaust Systems IMG_6049
michelle227
michelle
North Texas/South Canada
Badlands 2dr 7spd/ Mercury Grand Marquis/ Jaguar X-Type/ Fiat Spider
Dont forget the discount codes...JOLLY 20 and JOLLY25 - the percentage is keyed to amount of purchase. I was hoping to use it for the winch, but it's out of stock. I did get the exhaust for the 2.3L though...
B-rad351
B-rad351
Brad
WV
2024 Bronco
Yes! That’s why I want to purchase one. I also have some points I can apply to bring it down more. The purchase price qualifies for JOLLY20.
B-rad351
B-rad351
Brad
WV
2024 Bronco
I just bought this for my Big Bend 2023 2.7 Liter with the tow package on it. The JOLLY20 and JOLLY25 no longer work. Use the REDEEM1225 code.
Thanks! I just got in under the wire then with JOLLY20. I ordered the correct one for my 2024 Badlands 2.7.
Ride Em Bronco
Al
Pittsburgh, PA
2024 2-door 6-Speed Manual Big Bend Bronco
Now I'm confused - ignoring any holiday discounts - for the M-5230-BR3SC - which is the Ford Racing exhaust for the Bronco 2.3L - how can Ford Racing being selling these for $393.30 and all the other merchants are selling these for $1,300 - $1,400??
