EVERY SINGLE THREAD
Randy92Fox
Randy
Washington
66 Half Cab, 7.3 Powerstroke, 5.0 Convertible Fox
Hypothetically speaking, if the choice in that drop down list on the left column four spots from the bottom were to change but all other drop downs remained the same would the third line from the bottom on the right change?
Jook13
Josh
Prescott az
Suzuki samurai
And also if it's not the 7.3 V8 I'm getting the new Wrangler! *Ducks into fetal position*
Nanook
Jonathan
Raptor, Bronco, Galaxie, Ducati Streetfighter V4S
Still waiting to hear how a small displacement twin turbo 6 is going to manage heat daily driving and turning 37’s when the stock raptors overheat in the SouthWest.:devil:
frinesi2
MD
'92 Pajero 2.5TD, '99 Land Cruiser '15 Golf TDI
Just get some hood spacers on there.
Nanook
Jonathan
I thought the Bronco was rear engine now?
I mean the front suspension is like a side x side right?!:turkey:
frinesi2
MD
Yeah the hood spacer alters the boundary layer separation point on the front end to increase the reynold's turbulence at the point where it enters the proximal radiator inlet, improving the thermal efficiency of the convective heat transfer.
It's only a small improvement but any little bit counts when you live in satan's crotch.
JimmyDean
Louisiana
82 Bronco, 513 ci; 71 mach 1, 351C; 06 F-250, 6.0; 56 800, 172c.i. gas
As a M.E., ....I feel that I should know most of those words..
Nanook
Jonathan
It’s ok the aftermarket cooling on the Bronco R failed and I’m sure they knew some of those words LOL
