DV8 Offroad | Rear Window Molle Panels
DV8offroad
Riverside, California
dv8offroad.com
Bronco's & Jeep's
2021-2023 FORD BRONCO | REAR WINDOW MOLLE PANELS
The DV8 Bronco Molle Panels were designed to handle tough trails while keeping your gear securely stowed. The panels feature a special MOLLE (Modular Lightweight Load Carrying Equipment) system designed to securely attach various gear mounts. This offers flexibility in how you mount items – they could be strapped, bolted, zip tied, or even clipped onto the sturdy molle network. From first aid kits to recovery gear to tools, snugly store everything with these two panels!
The panels are designed specifically with your Ford Bronco in mind – they comfortably fit around the rear roll bars and can be mounted in multiple positions more easily thanks to their direct bolt-on installation. Plus, they’re as versatile as your vehicle: they work with or without a hardtop, so you don’t have to worry about taking off the top every time you want to switch up the way you store your cargo.
**Please Note: These are NOT compatible with soft tops or 2-door models.
Check them out here: https://dv8offroad.com/products/6th-gen-bronco-molle-panels-rear-window
Ford Bronco DV8 Offroad | Rear Window Molle Panels bronco-rear-molle-panel_1051x700
Ford Bronco DV8 Offroad | Rear Window Molle Panels bronco-ford-window-molle-panel_1051x700
Ford Bronco DV8 Offroad | Rear Window Molle Panels bronco-ford-rear-window-molle-panel_1051x700
Ford Bronco DV8 Offroad | Rear Window Molle Panels bronco-rear-window-molle_1051x700
Key Features:
  • Includes Passenger & Driver Side Panels
  • Mount Molle Bags, Med Kits, Tools, & Other Accessories
  • Keeps Gear Secure on Tough Trails
  • Micro-Texture Black Powder Coat
  • Sleek Design Conforms to Shape of the Bronco
  • Can be Run With or Without Hardtop
  • Direct Fit, Bolt-On Installation
Visit https://dv8offroad.com/pages/ford-bronco-bumpers-and-accessories to shop all of our Ford Bronco Parts and Accessories.
Plus... use code "ForumMember" at checkout for 10% off!
Herbie
Alex
Cleveland OH
2022 Badlands
Key Features:
  • Sleek Design Conforms to Shape of the Wrangler
Excited there is another option out there now. Thank you. You might want to proofread bullet point five before too many forum readers start razzing you ;) .
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
no soft top? is there one in the works? seems the majority of owners are soft top /shrug
DV8offroad
DV8offroad
dv8offroad.com
Bronco's & Jeep's
HAHA, thanks for pointing that out. Whoops
broadicustomworks
Hanging Rock, North Carolina
Ford Bronco DV8 Offroad | Rear Window Molle Panels 1670434266285
I assume it's that top outer corner/top outer edge that is the soft top interference?
I was all excited for a bit, ready to buy as the price per pair is really attractive.
But, soft top thangs....
