DV8 Offroad | Rear Speaker & Light Mount
DV8offroad
Riverside, California
dv8offroad.com
Bronco's & Jeep's
2021-22 FORD BRONCO | REAR SPEAKER & LIGHT MOUNT
This crossbar was designed to provide your Bronco additional mounting options for rear facing LED lights and speaker cans, or a speaker bar. It mounts directly to OEM locations with provided hardware, and is functional with your hard or soft top on or off.
The bar measures 29-inches in total length, and is 2-inches in diameter. There is a 10-inch slotted flat mount in the middle of the bar. 4 holes, 2 towards each end, allow you to run wiring hidden inside the bar. It is finished in a Micro-Texture Black Powder Coat, which blends well with the OEM trim.
There are several possible configurations you can run. Two speaker cans with roll bar clamps can be installed, with up to a 6-inch light bar or two 3-inch pod lights on the flat mount. You can run a 20-inch light bar across the length of the bottom if utilizing the back rail mounts on the bar. Alternatively, a speaker bar up to 28-inches wide with roll bar clamps can be mounted across the bottom of the bar.
***NOTE: This was designed for the 4-door Bronco models only, it does not fit 2-door models.
Check them out here: https://dv8offroad.com/collections/...roducts/bronco-roll-bar-speaker-light-bracket
Ford Bronco DV8 Offroad | Rear Speaker & Light Mount ford-bronco-speaker-light-mount_1050x700
Ford Bronco DV8 Offroad | Rear Speaker & Light Mount 2021-up-ford-bronco-speaker-light-mount_1050x700
Ford Bronco DV8 Offroad | Rear Speaker & Light Mount bronco-speaker-light-mount-bar_1050x700
Key Features:
  • Designed for Speaker Cans or a Speaker Bar with Roll Bar Clamp Mounts
  • 10” Flat Mount for Light Bar or Light Pods
  • 4 Hidden Wiring Access Points
  • 3mm Plate Steel & 2” x 1.5mm Tube Steel
  • Micro-Texture Black Powder Coat
  • Installs to OEM Locations
  • Retains OEM Antena Functionality
Visit https://dv8offroad.com/pages/ford-bronco-bumpers-and-accessories to shop all of our Ford Bronco Parts and Accessories.
Plus... use code "ForumMember" at checkout for 10% off!
Wannabe Techie
Chicago
Great idea! More lighting is good in there.
What speaker pods did you use in the pic?
P.S. Ordered - Send It!
DV8offroad
DV8offroad
dv8offroad.com
Bronco's & Jeep's
Rednek
Jimmy
Northern Alberta
2021 Bronco BD/2023 Maverick XLT/02 F150/68 Torino
like the idea of this but should have made it full width(and remove crap stock speakers) so you can still see behind.
Wannabe Techie
Chicago
DV8offroad
DV8offroad
dv8offroad.com
Bronco's & Jeep's
These in stock? Double checking they are shipping vs. preorder.
Will go great with my OE Plus and MTO bumpers. . Keep building Bronco stuff! Thanks.
YUP! In stock and ready to ship!
Lak34ers
Troy
Seattle
Key Features:
Just ordered. Very nice. Thinking about rear camera mounted to where light bar could go. Any advise or instructions on how you hooked up the additional speakers. A lot of discussion no how the rear speakers are already disabled when it comes to full sound.
Lak34ers
Troy
Seattle
Key Features:
Can you post an install video along with the before and after sound.
Cybindustries1904
Tony
Discovery bay
23 Raptor, Mach E GT
Need this for a 2 door
