Dubsesd Big Bend build!
Dubsesd
Andrew
CT
04 Ford F-150, 06 Roush Mustang
First day reservation
Ordered January 25th
Built on July 23rd
Delivered on August 23rd
Area 51
Mid package
Sasquatch
I will update this as I go on.
I have Zone off-road leveling kit that I have to install and I have speakers and amps ordered.
I plan to wrap the full Bronco in Xpel Stealth PPF
When I picked it up at the dealer!
Ford Bronco Dubsesd Big Bend build! 973500E9-1671-46A5-8AEA-FC45908AA73B
Ford Bronco Dubsesd Big Bend build! C88BA8F0-D0C7-4F00-9DDE-7720EFE8CFC8
Took the keypad off the door and placed on the pillar. IMO it looks better.
Ford Bronco Dubsesd Big Bend build! E32C1EDB-B0CD-4BFB-8CAC-324B66278FD5
Ford Bronco Dubsesd Big Bend build! 1F2F40EB-716D-404A-9E40-E577B27CD429
Installed Zone 1” leveling kit
sorry I’m really bad at taking during pictures so I just have the after photo.
Ford Bronco Dubsesd Big Bend build! 7E9C4FEB-80AC-4AA2-829D-32B76DD5D03D
Installed PPF over the weekend with a friend.
Ford Bronco Dubsesd Big Bend build! A08948B6-D2E8-4D37-B3DD-57CCE35D803C
Ford Bronco Dubsesd Big Bend build! 166BE20B-0B37-4EF4-B8A8-C4DF74148378
Ford Bronco Dubsesd Big Bend build! C5B97D97-708F-475B-B442-E961C06DD62C
Ford Bronco Dubsesd Big Bend build! 2A1FA206-0E47-442B-AA41-D90177226727
Ford Bronco Dubsesd Big Bend build! 35BAE882-7421-4791-9820-A23BE3A10E10
Ford Bronco Dubsesd Big Bend build! 1CFE44DB-5D47-4D32-BF1D-035459FD78B5
Ford Bronco Dubsesd Big Bend build! 759DA827-C902-4B11-8FA6-17187A937B7C
Ford Bronco Dubsesd Big Bend build! F446FB71-9FFA-4887-ADBA-A0CE6E9557A2
Ford Bronco Dubsesd Big Bend build! E41F5350-058B-4C3E-824F-111D4CC811E7
Ford Bronco Dubsesd Big Bend build! 2A94DA38-5F75-4162-B216-EE28452C73FB
Ford Bronco Dubsesd Big Bend build! 7284F8DF-72CE-48CF-940A-9A129AE421C9
Chuck_Ruck
Chuck
Arizona/Nomadic
F150, Wrangler, Eldorado, Harley, Triumph
Tinted windshield? I mean I have the top strip, but the whole thing? Are laws more relaxed for your state?
CMBRONC
So Cal
None
Per CT state law:
Windshield: Non-reflective tint is allowed above the manufacturer's AS-1 line. Front Side windows: Must allow more than 35% of light in. Back Side windows: Must allow more than 35% of light in. Rear Window: Any darkness can be used.
Dubsesd
Dubsesd
Andrew
CT
It’s not legal but our inspection doesn’t check for it and the police don’t enforce it where I am.
Pressurized
Rod
Gilbert, AZ
Gen 6 Bronco - Jeep JKU - Wrangler LJ (sold)
Just a little PSA for you... If you are in an accident and a good attorney finds this? They will own you. Good luck.
VABronco
Leesburg, VA
‘21 Bronco, ‘07 Chevy Avalanche
Build on July 23rd
Area 51
Mid package
Sasquatch
How did you remove the keypad from the door? I am thinking it is just 2-sided tape but curious if you heated it or how did you get it off so cleanly? I want to move mine as well. Thanks
Dubsesd
Dubsesd
Andrew
CT
its just double sided tape. On a hot day I just used fishing line. Then used rubbing compound to remove the small amount of adhesive left.
VABronco
Leesburg, VA
On a related topic, my dealer did not give me the card with the keypad code on it. I’ve tried to place both keys in the console slot turning it on / off as instructed on the app, but the code is not showing up on the dash display like they say it would. Any advice on how else I can retrieve the code before I go back to the dealer and have them figure it out? Thanks
Dubsesd
Dubsesd
Andrew
CT
Yes! On the driver side fuse box (pop down the bluster panel) you will see a card on the face of the fuse box with the code. Let me know if you need me to take a pic and show you.
VABronco
Leesburg, VA
This is for a full size Bronco and not a sport, right? I only see a drivers side fuse box in the engine compartment and I popped off the lid but don’t see any card with a code. If you could provide a pic that would be much appreciated.
VABronco
Leesburg, VA
Build on July 23rd
Area 51
Mid package
Sasquatch
I have Area 51 as well but Outer Banks. I am looking to install leveling kit and put on some bigger tires / custom rims.
Ford Bronco Dubsesd Big Bend build! 1F2CB203-B412-483D-B901-591D02EA4A68
BE5OME1
Pete
2020 F150 SXT 4x4, 1967 Mustang, 1975 Bronco
Build on July 23rd
Area 51
Mid package
Sasquatch
man that looks much better I didn't order from factory cause I hated it on the door. Now dealer wants $100 buck for keypad and $125 to program. I want one for my F150 and my Bronco.
Dubsesd
Dubsesd
Andrew
CT
You have to pull this panel down. It just clips.
Ford Bronco Dubsesd Big Bend build! A4D3B1EC-1072-403E-8FD1-CDFFEAE9C4B4
Ford Bronco Dubsesd Big Bend build! 7AD397A2-195B-463E-AD18-3A28EDDA4DDD
Ford Bronco Dubsesd Big Bend build! FB15AEA1-9C6A-41CB-A3D9-D109DF4043C2
VABronco
Leesburg, VA
Thanks, I found the code but it still will not open the doors when i enter it on the keypad. The doors lock when I hit 7-8 and 9-0 together, but I cannot unlock by entering the code.
