Dual LED Light Reverse Kit w/Diode Dynamics Lights | TRAILER CONNECTION
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Looking to get dust lights or reverse lights for your vehicle? We've got you covered with this Diode Dynamics Reverse Kit. This kit comes with lights, brackets and wiring harness making it a breeze to get rear facing light setup on your truck! Everything you need in one kit.
https://www.4x4truckleds.com/dual-l...-diode-dynamics-lights-7-pin-trailer-harness/
This is a completely bolt-on kit offering a simple plug and play installation (if your truck is equipped with a 7-pin trailer harness with a disconnect on the inside of the bumper). The kit utilizes the Diode Dynamics 7-pin dual-output trailer wiring harness, which plugs in-line with your existing trailer harness behind your hitch. This configuration ensures you retain functionality of your trailer harness while keeping the plug behind the trailer hitch out of sight. Completely plug and play!
The kit includes a a red back-light feature which creates a red glow from the light housing whenever your indicator/headlights are on. As soon as you switch into reverse this red light turns off and the main white output turns on, giving you some much needed visibility behind your truck. (Note: If you do not want the red backlight to turn on, you can unplug/cut the backlight control wire on the back of the light's harness).
The included KR Off-Road extension bracket allows the lights to hang from factory bolts under your truck. This bracket is made right here in the USA out of 11 gauge stainless steel (and powder coated black) ensuring a lifetime of durability.
Here are shots of it on our Lightning as an example but it'll work on the Broncos also of course!
Ford Bronco Dual LED Light Reverse Kit w/Diode Dynamics Lights | TRAILER CONNECTION 1673987728449
Ford Bronco Dual LED Light Reverse Kit w/Diode Dynamics Lights | TRAILER CONNECTION 1673987733270
Ford Bronco Dual LED Light Reverse Kit w/Diode Dynamics Lights | TRAILER CONNECTION 1673987738914
Ford Bronco Dual LED Light Reverse Kit w/Diode Dynamics Lights | TRAILER CONNECTION 1673987743916
INCLUDES
  • 2x Diode Dynamics Lights
  • 2x KR Off-Road mounting brackets
  • 1x Diode Dymamics 7-Pin Dual Output Trailer Wiring Harness
SSC1 are 1" Pods.
SSC2 are 2" pods.
SS3 are 3" pods.
  • SSC1 Sport: 1,030 lumen each
  • SSC2 Pro: 2,300 lumen each
  • SSC2 Sport: 1,130 lumen each
  • SSC2 Pro: 2,898 lumen each
  • SS3 Sport: 2,262 lumen each
  • SS3 Pro: 5,796 lumen each
  • SS3 Max: 7,920 lumen each
COMPATIBILITY
Your truck must have a 7-pin trailer harness on the backside of the bumper (on the Bronco, it's located to the left of your trailer hitch. You'll need to remove 1 bolt to access it easily and then you can put the bolt back on). This harness must be able to disconnect as the included harness in our kit is an in-line connection. This means you will disconnect your factory 7-pin trailer harness and plug in our harness (your factory harnses then plugs into our provided harness). The back of your bumper will look similar to this, behind the trailer connection:
Ford Bronco Dual LED Light Reverse Kit w/Diode Dynamics Lights | TRAILER CONNECTION trailer1
The rear of your bumper must also have 1 bolt on each side that our bracket can hang from. Most bumpers have some type of brace/support bar and bolts. If you look at your bumper, on the back side you'll want to look for one bolt on each side. In this photo you can see this truck has 2 bolts we can utilize to hang the light from using our supplied bracket.
Ford Bronco Dual LED Light Reverse Kit w/Diode Dynamics Lights | TRAILER CONNECTION trailer2
INSTALLATION
1) Unplug your factory 7-pin trailer connection from behind your bumper
2) Plug the included Diode Dynamics harness into the factory harness
3) Plug the other end of the Diode Dynamics harness into your trailer connection on the back of your bumper
4) Route each leg of the wire harness to each side of the bumper
5) Mount the Diode Dynamics lights to the KR Off-Road brackets
6) Mount the KR Off-Road bracket to the back of your bumper utilizing factory bolts. The KR Off-Road brackets have a lot allowing you to raise/lower the lights to your preferred height
7) Plug the lights in and away you go!
Klink
Pennsylvania
2013 f-150 FX4
These are some great options to add some (much needed) back up lights. I have the hitch mounted pod installed. The other added benefit is it disables the auto start/stop by tricking the bronco into thinking its hauling a trailer. Unfortunately, it also disables some other nanny features and displays this fact on the dash EVERY time at start up. Is there any work around for this? I do miss the blind spot monitor that lights up on the side view mirrors.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Our reverse kit does NOT make the truck think a trailer is connected.
Klink
Pennsylvania
2013 f-150 FX4
Not bashing. Only looking for help.
Klink
Pennsylvania
2013 f-150 FX4
It also disables the rear park assist.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
You're on the wrong thread... this is a thread for our REVERSE KIT. Not the HitchPod... two different products.
If you're a customer of ours that bought the hitchpod, let me know your order # via a PM and I can help you get it working
F OR D
BD Green Machine
still waiting for that 3rd brake light replacement that has reverse/aux ;)
4avor8ntfair
Houston, TX
BL-non SAS, 2.3 auto
INCLUDES
SSC1 are 1" Pods.
SSC2 are 2" pods.
SS3 are 3" pods.
COMPATIBILITY
INSTALLATION
Does the hitch pod work with this kit, like shown on your truck? Plans to offer a flush-mount option? I wouldn’t want lights hanging below the bumper.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Yeah but on a Bronco since there's no bumper to hide the trailer connection.. you're going to have a harness sticking out (2 of them) daisy chained to each other that you'll need to zip tie out of the way.
I have the hitch pod plugged into our reverse kit plugged into the trailer connector on our lightning.
No we don't plan to offer a flush mount kit like this. The idea is it's plug and play and a quick install. We already sell flush mount kits that include our harness to route it to your upfitters/tap into your reverse circuits
