Drop steps for rock rails
mm.bronco
Pennsylvania
Does anyone know of some good drop steps options to add to the factory rock rails? I don't plan to remove them often, if ever. I've seen the IAG steps and similar steps, but I want steps that are hopefully a few inches lower than the rock rails. Thanks!
Mr Toad
Ben
Pacific Northwest
2023 Bronco Badlands Sasquatch 2dr
Here’s the Broaddict steps (pretty much the same as iAG) on my 2Dr Badlands Sasquatch. They are pretty much at the bottom of the factory rail. Step up is 19” instead of 26-1/2”. Much easier to get in, particularly if you also add grab straps to the roll cage above the door. These also don’t reduce ground clearance since they don’t drop below the factory rails but are easy to remove trail side as well. https://amzn.to/47QXv9i
The door sill protector is also a simple add and looks nice. It's already saved a few scratches. https://amzn.to/49cWNUG
Ford Bronco Drop steps for rock rails IMG_9099
Ford Bronco Drop steps for rock rails IMG_9098
Ford Bronco Drop steps for rock rails IMG_9217
