Drivers Window Whistle
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
So, not sure along the way when it started. I have a 2021 4D that started life as a soft top, now running the Turn Offroad Hard top with a Trailrax. When driving through a crosswind, the the drivers window tends to whistle significantly. If you press on the top of the window from the inside, the issue gets worse, which was how I pinned it down.
My inclination is to repeat the window adjustment procedure that got rid of the rattling through the boots at the bottom of the door, but if there are any other places I should check I could use a few pointers.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
So, not sure along the way when it started. I have a 2021 4D that started life as a soft top, now running the Turn Offroad Hard top with a Trailrax. When driving through a crosswing, the the drivers window tends to whistle significantly. If you pretty on the top of the window from the inside, the issue gets worse. My inclination is to repeat the window adjustment procedure through the boots at the bottom of the window, but if there are any other places I should check I could use a few pointers.
Hello! Send us a private message with your VIN and current mileage. Allow me to see what I can do to assist. Thanks!
Migo
Roy
Houston, TX
www.instagram.com
I had the same problem on my passenger side window. Adjusting the bolts at the bottom of the door corrected it for me.
1st 75th ranger
jeffrey
nj
you tube reset windows ...that should help
