Driver's Side Window Rises Prematurely
StrainedCMOS
Vancouver, BC
2023 Ford Bronco
When closing the driver's side door, sometimes the window rises up to seal before the door is closed and gets stuck outside the track until I roll the window down and reclose it.
Anyone else have this issue? If I don't close the door in one smooth motion this issue occurs.
Reidt131
Reid
Howell, MI
Bronco Big Bend
Yeah I've noticed this too. Could be unrelated but my Bronco alerted that it was doing a factory reset and then updated. Seems to have gotten more frequent after that point so maybe a software issue?
StrainedCMOS
StrainedCMOS
Vancouver, BC
2023 Ford Bronco
I've had the issue since I took ownership of it. I can easily recreate it by closing the door, slowing it down then completing the door close. It is as if the slight deceleration is causing a sensor to think the door is fully closed when it is not.
