Driver widow auto-close stalls
DenNut
Troy
Denver, CO
I’ve noticed that the auto-close for my driver window doesn’t close on its own to completion. It will get 1/4 -1/2 closed and then stop. That is not the case for the other windows. is this the case for anyone else?
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
There is a procedure in the Technical Service Manual to re-initialize the power door windows...
Ford Bronco Driver widow auto-close stalls Power Door Window Initialization
PS - Please accept my condolences for the driver's widow. 😢;)
DenNut
DenNut
Troy
Denver, CO
Thank you for the tech note! We’ll see how it goes this week.
DenNut
DenNut
Troy
Denver, CO
unfortunately, this didn't fix my issue. IT seems like about half the time when I use the switch on the console, the window stops before closing all the way. It's not every time. but it does happen frequently. If I'm the only one with this issue I might have to schedule an appointment. :-(
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hey there! I can look into your Bronco’s window concerns on my end if you’d like. Will you send us a private message with your VIN and dealership info?
judgefudge72
WA
22 OBX High Sas
My front passenger side window does this but I’ve noticed it’s mainly when I already have at least two windows going up. Like when all the windows are down and I put up the back ones first then do the fronts.
augidog34
Will
Chicago, IL
2021 Bronco Big Bend
I'm getting the same issue with my driver side window. Originally, the passenger window would stop 3/4 way up, then it closes and comes down about that same distance. The dealership "fixed" it, but it hasn't stopped. Now, my driver's side window has completely stopped going "automatically up". I have to hold it get the whole way up.
Yukon65006
Central WA
09 Jeep Patriot, 06 BMW F650GS
Same random issue with front passenger side.
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
You’re not the only one.
Kimberley
Vermont
Mine have done this a couple times as well over the last couple weeks, but I have also had all 4 windows down and have been putting them up all at once so that might be the issue.
augidog34
Will
Chicago, IL
Oh man, so I just went out to the garage and spotted how big of a problem this is. If the windows don’t “go down then up” on their own when you open and close the doors, it looks like this. That’s a decent gap!
Ford Bronco Driver widow auto-close stalls 7EAA1694-E9F7-4835-88E5-E368306B3672
augidog34
Will
Chicago, IL
This tech sheet actually worked! Thanks for posting it!
bhb
N NJ
Same.
Happens most often when I roll all 4 windows up at the same time. Typically right front (passenger) window.
TigerBronco
Charles
2011 F-150 F/X 4, 2019 Honda Odyssey, 2001 Nissan Pathfinder, 1992 BMY M923A2 M
You are not the only one. Happens to me, seemingly randomly, every so often. Just have to cycle it a time or two and all good.
I haven't tried the reset procedure yet though. I've just been dealing with it.
HorizonHunter
Joseph
Chapel Hill, NC
Grand Cherokee Trailhawk
Same.
I'm in the same boat. Same window, same scenario.
