Driveline pics *nerds only*
IV.f
Co
Wrangler JK
Any one know what BW T-Case number this is; hoping it’s new and close to what the raptor has but probably the 4417
Ford Bronco Driveline pics *nerds only* 1599598210559
Silver-Bolt
Eureka, MT
With any luck you'll never need to know. Integrated Wheel End. Another word for it is junk.
Ford has dropped the vacuum operated IWE in favor of electronic version. Not sure if that will apply to the Bronco but it likely will. The 2021 F150's should now have the electronic version. The Vacuum version is a nightmare.
BearWithMe
West Slope, Colorado
2018 Tacoma 6MT
Do you have more info on this? I haven't come across any info on a change from vacuum IWEs. Anything would be an improvement over existing, I bet.
Silver-Bolt
Eureka, MT
Nothing that can be officially disclosed. My company is a supplier to the company that makes the IWE's. The 2021 F-150 should be the first vehicle to have the electronic IWE. Yes, it should be a huge improvement over the vacuum version. No idea if the Bronco will receive the same setup.
Rednek
Jimmy
Northern Alberta
I won't recognize any of this in the dealership,need to cover it in mud up to the frame rails and have a mad customer standing there wondering why everything went to shit
Megawatt
JO
Where the asphalt melts in the Summer
Lifted Rubicon usually off-road.
Ok, who else jumped immediately to the second pic to look at the tire/wheel? I did.
Megawatt
JO
ok nerds, did you notice the rear diff cover? It looks like the edge of the cover is a couple mm away from the housing edge. It’s smaller than the machine edge it is bolted to. This will help to prevent the dreaded Oops of peeling back the diff cover when it drags on a rock and dumping all your diff oil on the trail.
Many off-roaders invest in a thicker iron aftermarket cover to prevent the peel back possibility.
jeep364
2007 Jeep WK
This is most likely incorrect. Ford has possibly made it worse. Vacuum line still present but electronic addition.
See:
https://www.f150forum.com/f129/2021-4x4-system-492943/ (read the whole thread, i'm sure more info is coming)
https://www.autoblog.com/2021/01/28/2021-ford-f150-suspension-deep-dive/
Silver-Bolt
Eureka, MT
kodiakisland
Arkansas
So, let's talk pan hard bar and lifts. Is there a difference in the bar or mounts on the squatch vs standard suspension? Is this new bracket to run 37s welded on? I understand all the up front stuff I need to do in a lift, but am not as well versed on anything not a leaf spring rear setup. What will need to be done to lift a couple of inches to keep the rear axle centered?
Ford Bronco Driveline pics *nerds only* 1612684024426
Ford Bronco Driveline pics *nerds only* 68EAEA37-8241-4865-BB7C-BD5733453D1F
Bronco_joe
joe
Niagara Falls. NY
not sure on the factory differences. that procomp one looks to be adjustable and have a raised bracket on the other side. you won't need to weld anything on
kodiakisland
Arkansas
So the new bracket on the axle is bolted to the existing bracket? Just hard to tell what’s going on in that picture.
